Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-04-2006, 03:24 PM
SySt3mR00t SySt3mR00t is offline
Send a message via AIM to SySt3mR00t
4G63 Proper Break In
Hey guys, back with more questions .... well im almost done with my stroker kit rebuild. So i thought this would be perfect timing to ask the BIG QUESTION! How should i break in my car. I have brand new clutch new flywheel and brand new stroker motor. What is the best technique to break in the motor? How many miles? When to change oil? ETC.... PLEASE LET ME KNOW. ... THANKS SOO MUCH !
96 GST
Old 05-04-2006, 03:33 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: 4G63 Proper Break In
If you search, you shall find.
IIRC change the oil after 5 miles, 50 miles, and 500 miles and dont boost/take it about 3k rpms for the first 500 miles. I'd personally take it easy longer than that, but thats just me.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 05-05-2006, 12:24 PM
keymaster4225 keymaster4225 is offline
If you baby it like that, your rings will never seat properly and you'll never get full compression. You have a window of like 20 miles to seat the rings, and the only way to do that is to beat the piss out of it. Go here: http://www.mototuneusa.com/break_in_secrets.htm for more info.
1996 Eagle Talon TSI AWD
Mods:
6-bolt motor stock specs
MHI S16G turbo
FMIC: 28"x10.5"x3.5"
PTE 780cc injectors
Walbro 190lph fuel pump
3" custom turbo-back exhaust
DSMLink tuning platform
ACT 2600 clutch
20lbs of boost
Old 05-05-2006, 02:24 PM
steviek's Avatar
steviek steviek is offline
That site seems to me to be primarily focused on bikes. I know the "logic" carries over into cars as well but it still doesn't sit well with me. Just seems to me that one could argue that running your engine hard EVER is not a good idea so during the break in period it just doesn't seem like a good idea for me. I see their point but Its still unclear whether A (running the engine hard) causes B (sealed rings) or they are just looking for a correlation between them.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 05-05-2006, 02:39 PM
well ... still havent made up my mind .... im having trouble with reinstalling my msd ignition right now ..car cranks over .. but only fires sparkplugs 2 and 3 .... workin on it still .. but car will be running soon...
hmm.... who else has feedback .. RUN IT HARD on break in ... or EASY on break in ... PERSONAL EXPERIENCES would be appreciated
96 GST
Old 05-05-2006, 03:14 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
EASY! DEFINITALLY TAKE IT EASY! We put o new motor in a friend of mines 68 SS, its no Mitsubishi, but there where about 6 Life long mechanics working on the car, and all of them said to baby it, and change the oil after 50, then 100... then 500, then 1000... etc... it was a Edelbrock 454 crate... but i would never Push my BRAND New Stroker motor w/o an easy break in...
Old 05-05-2006, 03:23 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
When I was breaking in my high compression SBR crate motor, that is exactly what Kevin said when I proposed babying the car. Keep the RPMs decent, I would not go over 3500RPM, but boost 10-15psi, so give it a little throttle now and then.
When breaking in my motor, we used cheap 20-50 non-synthetic Penzoil. You will be changing the oil so regularly during break in , do not worry about the cheapness of the oil. Oil and filter [mitsubishi OEM only] were changed at the following intervals:
100 miles
200 miles
300 miles
400 miles
500 miles
1000 miles
2000 miles
3000 miles
after the first 3000 miles, we reverted back to the regular interval of ever 3000 miles.
And thankyou for posting in the appropriate sub-fourm, what a breath of fresh air!
The daily driver. The weekend cruiser. The lazy shop hog.
Old 05-05-2006, 03:48 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
With modern motors there really isn't that big of a break in period. The rings never really "seat" in the block because they, in theory, should never touch bare metal. You can use any oil you want to, the myth that you cant break in a motor with synthetic is just BS. Anyway my :2cent: is do what feels right to you because everyone will have a slightly different approach to it.
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 05-05-2006, 08:48 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
You can send the motor to me and I will break it in for you
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 05-06-2006, 04:28 AM
E-Klips E-Klips is offline
Banned
That also isnt a turbocharged engine. Naturally aspirated motors dont require such break in processes.
Break the motor it hard. Set boost at whatever you are going to run daily. When you offically start it up, let it idle up to operating temp, change the oil and filter, then go for your vacuum pulls. Bring the car to redline WOT in 2nd or 3rd gear and just let of the gas to let the engine slow the car down. Do this 5-6 times... Your rings should be good to go after that. You can go home and check the compression to make sure it is good, if not, continue to do the same thing. If everything is good, change oil and filter again, then drive on. Change at 100 miles, 500 miles, 1500 miles and 2.5/3k miles (whatever you prefer to change it everytime).
Its not rocket science... Think about it, if you are building a forced induction motor, why would you break it in like a naturally aspirated motor and run it in vacuum the whole time??
Old 05-06-2006, 11:55 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
I agree, I was always told to drive it how its gonna be driven all the time or it'll never get broken in right.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 05-07-2006, 02:14 AM
kjewer1 kjewer1 is offline
AF - Advisor
http://www.automotiveforums.com/vbul...breaking+motor
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-07-2006, 05:43 AM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
Originally Posted by 95 GSXracer
When i was reading that i noticed the part where you said breaking a new motor in kills the turbo everytime!!!! So whats gonna happen to me when i finally start my freshly rebuilt motor up for the 1st time and run it for a while?
Is it gonna kill my turbo? My turbo only has 3k on it so its still new.
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 05-07-2006, 07:14 AM
AF - Advisor
Most likely The only turbo I've had survive was the T67, and that ran an AGP issue oil feed line filter. Any 10 micron filter that flows well and has 4an ends will work. ~40-60 bucks well spent IMO! Many poeple run spare 14bs or similar to break in motors. Other's take it to the extreme and weld up old center cartriges to block passages or otherwise run NT for the breakin. I don't recomend that though, since it makes it impossible to break it in "hard."
Kevin Jewer
Old 05-07-2006, 07:48 AM
Thor06's Avatar
Jizzed In My Pants
Hey, sorry for the thread jack, but I figured a second thread about breakins would be pointless. What kind of a break in would one need to do for new cams and planed/valve job'd head?
