Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 05-04-2006, 03:19 PM
GreyGoose006 GreyGoose006 is offline
Gas Shocks
Im having the worst time getting my new KYB gas shocks on. the rears were easy enough, but the rears are proving to be a real hassle. i cant get them to compress enogh to bolt them in. right now im using ramps which may not be the best way, but im not sure im comfortable being under a car that is only held up by a jack. any ideas on how to do this correctly?
Old 05-05-2006, 12:08 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
Re: Gas Shocks
i imagine you have the jack under the rearend, its keeping the weight of the car on the rear suspension, go buy some jackstands and put them under the frame rails to let the rear end hang down a bit, making it easier to install the shocks
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 05-05-2006, 04:21 PM
Re: Gas Shocks
no, you misunderstood. i did the rears easy enough by rolling the car on to ramps and compressing the shocks enough that i could put them on. the problem is that in the front there is not enough room to do this. i have jack-stands, but im not sure how to use them.
Old 05-05-2006, 04:41 PM
1986Z28's Avatar
Has a Camaro
Re: Gas Shocks
oooohh, i was confused because of this the rears were easy enough, but the rears are proving to be a real hassle, didnt know what you meant so, if you have jackstands, there easy to use just jack up the front end, stick under the frame rail(dont know the exact position for your car) lower the car down slowly, dont let the jack down all the way, then check to make surethe car isnt going to move(wheel lock a good idea but a block of wood will also work) then just take out the jack
Old 05-05-2006, 09:59 PM
CD Smalley CD Smalley is offline
Re: Gas Shocks
GEt a deep socket and as long as possible of an extension. Put the on the nut on top and start rocking it back and forth. Eventually, you will break the shaft and the shock should drop free once you remove the two lower bolts.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 05-05-2006, 10:08 PM
Re: Gas Shocks
Sorry, i have become inept at typing.
the top seems to screw into a nut on the top of where the spring mounts. the nut seems to be hidden from the bottom.
am i just missing something obvious here?
Old 05-05-2006, 10:17 PM
alphalanos alphalanos is offline
Re: Gas Shocks
You should be able to see the shock mount bolts as well as the shock rod bolt from inside the engine bay.
96 EJ6. Future home of boosted B18C1.
Old 05-05-2006, 11:09 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Gas Shocks
The nut that holds the top of the shock onto the body mounts through the frame (with the shock below the frame) and is accessible from under the hood. Look down at the upper control arm, you will see the nut toward the top between the control arm bushings. You might need to hold the shaft to prevent it from turning while loosening and removing this nut - a pair of channellock pliers work great here. Just don't use them on the new shock.
You will first have to jack the car up as if to change the tire - jack it up high enough where you can put a jackstand under the frame behind where you have the jack. Lift it high enough so that the bottom of the tire is about 2-3" off of the ground - you will want as much height as possible here. After removing the top nut and the two bolts on the bottom of the shock, it will easily come down through the spring and out the bottom. Installation is the reverse of removal; however you will likely want to compress the new shock a bit before installing it, and get one of those bottom bolts in before it totally uncompresses. Pay particular attention to the rubber bushing that mates with the frame - on the shock rod with the nut.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 05-06-2006, 05:28 AM
Blue Bowtie's Avatar
Registered Offender
Re: Gas Shocks
And don't forget to bleed/purge the shocks before you install them. I'll bet almost no one does that any more, but it's just as important with gas-charged shocks.
Old 05-06-2006, 01:57 PM
Re: Gas Shocks
Well i wish i had read this before i finished installing them. what does this mean and how do you do it? is it important enough that i want to un install them and re do the whole thing?
btw, the nut on the top of the shaft was accessable thru a hole in the upper control arm. after using lots of WD-40 and much swearing, i managed to get the nut off. channel locks were absolutely no help in holding the shaft. i ended up needing to get a set of vice grips so tight that they were nearly impossible to un lock before they would hold the shaft hard enough to get the nut off (WOW that sounds gay)
the new shocks are KYB gas shocks and as you know, gas shocks are load-bearing, so compressing them was no easy task. i used a jack to get them into place and hold them there.
anyway, now it rides w/ much more control. the only complaint is that the car now rides 2-3 inches higher than before.
Oh Well, i can just get some 22" and it'll look O.K.
J.K
i wouldnt reeely do that
Old 05-06-2006, 02:02 PM
Re: Gas Shocks
Oh and thanks for all the help... ;-)
Old 05-07-2006, 04:42 AM
Registered Offender
Re: Gas Shocks
If they are gas charged shocks and came with a retention band, you should have released the band whne the shocks were upright. There is no way to get 100% oil fill in a shock, so allowing the shock to extend while upside-down can introduce some air into the dampening cylinder. The only problem with this is that fine control is lost since the first bit of travel is unmetered because the valves don't do well with air instead of oil.
Old 05-07-2006, 09:26 AM
Re: Gas Shocks
the rears came w/ a retention band, and i attached them at the top, then released the band and pushed them onto the bottom mounts on their way down. the fronts had no bands
Old 05-08-2006, 07:36 PM
TommySS TommySS is offline
Re: Gas Shocks
bleed/purge? You mean cycle the shock, right?
It's not difficult to swap shocks, but you need to allow the lower A-arm to hang low (jack car from frame). Bolt the bottom portion of the shock into he lower A-arm, and then slowly raise the lower A-arm. Then add the nuts onto the top shaft of the shock and torque to spec.
Old 05-08-2006, 09:23 PM
silicon212's Avatar
Confoundingly Lucid
Re: Gas Shocks
The only problem with this is that a new shock is going to be fully extended, and that's a larger distance than the top mount to the bottom mount with the arms in the fully lowered position (as low as they'll go without removing the lower ball joint). The shock has to be compressed in order for the thing to even have a chance of getting the bottom bolts in. I generally take a shock from the box, remove the retention band, then compress it all the way in and hope I have the shaft lined up with the hole in the frame - because it's going in fast. Once one of the bottom bolts is in at least two threads, you can finish installing it. I always tighten the top nut as the last sequence of the procedure. I also disregard what a manual says pertaining to torque on the nut - I tighten it down until the bushing begins to distort - whether with rubber or urethane. In 25 years I've never had one come loose - but I have saved a few bushings.
