Old 05-04-2006, 03:37 PM
MIKES3's Avatar
MIKES3 MIKES3 is offline
Trans Pan Bolt Torque Specs
Does anyone know what the torque specs are for the trans pan? Better yet does anyone have a shortcut on all the otrque patterns?
2004 GTP
3.2 MPS, FWI 9 inch K&N, ZZP motor mounts mandrel bent 2.5 inch exhaust w/ flowmaster 40s, resonator delete, 3" DP w/o CAT, MSD coil packs Autolite 104s, Autometer Boost Gauge, DHP Power Tuner, S&S Ceramic Costed Headers, W-BDY Store STG III IC, Hawk PADS Power Slot Rotors, 1.8 Roller Rockers, 90lb Springs, LQ4 MAF
14.5 stock w/ 2.2 60'
Old 05-04-2006, 04:54 PM
Ogre1 Ogre1 is offline
Re: Trans Pan Bolt Torque Specs
97 in/lbs or 11Nm.
Old 05-04-2006, 07:27 PM
BNaylor's Avatar
BNaylor BNaylor is offline
The torque specs on a 4T65E tranny oil pan bolts has always been 10 ft-lbs or 120 in-lbs. The 04 Grand Prix GTP has a MN7 4T65E-HD autotransaxle just like the '97 - '03 GTP.
You torque the inner most bolts first on each leg and work your way out to the corners.
Timeslip 08/12/06
AF Community Guidelines
Old 05-05-2006, 10:35 AM
Hmm, maybe I was mistaken
Old 05-05-2006, 11:24 AM
BNaylor's Avatar
Not a problem. We all make mistakes. However, your torque value looks like they are on target for the older 4T60/60E tranny pan bolts.
Timeslip 08/12/06
Old 05-05-2006, 12:14 PM
That would make sense as I was lookin at the specs for my '99's tranny.
