Go Back   Automotive Forums Car Chat > Mazda > B-Series/Bravo/Bounty/Drifter
B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version.
Old 05-04-2006, 02:04 PM
zoom zoom zoom zoom zoom zoom is offline
Question 87 B2200 oil pump
My truck recently started making a loud rattely type noise its in the timing belt area Im pretty sure the oil pump is shot mine has a gear right below the idler pulley the book says that is the oil pump but is that all there is to it ive never had mine off before and the oil pump picture online from advance auto parts.it doesnt look anything like mine any help would be greatly appreciated.
Old 05-09-2006, 10:37 AM
hocbj23 hocbj23 is offline
Re: 87 B2200 oil pump
Is oil pressure light on? If not may be tensioner on your belts going bad . Check it before replacing pump, lot less expensive.Also if rattle occurs mostly at start up may be the common "Mazda rattle" associated with valve train wear and oiling issues. Switch to a good sythetic oil, use a little Seafoam when you change oil and see if that helps. BJ
Old 05-09-2006, 02:00 PM
Yes thanks all the other stuff is fine I kinda want to replace the oil pump cause I overhauled the bottom end rings,rods,mains I just dont know what im getting into is if someone has a picture of mine that'd be great.
Old 05-21-2006, 11:15 PM
On my 87 B2200 with timing belt After taking my front off the motor the Gear below the Idler pulley is the WATER pump it was shot the back part fell off when I got it out,I just cant believe the Haynes auto repair Manual chapter 2a-10 calls part#9 an oil pump book 61030 mazda pick ups 1972 thru 1993 and then in chapter 3-4 it calls the same part#9 a water pump.but its OK at least my oil pumps ok.
Old 05-22-2006, 06:14 AM
I am glad you found the problem and hope your ride is working ok now. BJ
Old 05-22-2006, 09:57 PM
Kyrasis6's Avatar
Kyrasis6 Kyrasis6 is offline
Send a message via AIM to Kyrasis6
The oil pump is a trochoid gear type which is driven directly off the crankshaft. For future referance info you might want to check this out:
B2200 Tech Page
Although its too late now there is also a coolant diagram which has a picture of the water pump and some other info.
Edit: Also the oil sending unit doesn't trigger the light until it gets to 3 psi or less. If it gets below about 10 psi your screwed anyways, that is why its called an idiot light because if you don't realize something is wrong before it comes on you probably shouldn't own a car.
Owner of Mazdatruckin.com
Old 05-24-2006, 03:01 PM
H-m-m.I would be willing to bet there are a lot of responsible car owners out there who can't anticipate issues with their cars, but who certainly know that if an "idiot lite" comes on, it is time to find a shop or mechanic pronto to dx or fix the problem.My spouse being one of them and I guarantee that she knows plenty enough to own a car.BJ
