Old 05-04-2006, 01:49 PM
mothof3 mothof3 is offline
How do you remove the hamonic balancer
Help can someone walk me step by step in this please?95 Buick lesabre
Old 05-04-2006, 11:18 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Re: How do you remove the hamonic balancer
Search the forums...and get a Haynes or a Chiltons. A shop manual is even better, if you can get a hold of one.
Anyway, you're first going to have to jack up the pass. side, take off the front tire and inner splash guard, then get a socket large enough to fit the balancer bolt. One trick to get it loose is to jack up both sides of the car, pull the plug wires, jam a sturdy pry bar on the socket (and set it against part of the frame that is sturdy, then crank the car over to spin the balancer and therefore breaking the bolt loose enough to remove w/ a ratchet.
From there, you may need a balancer puller (should be able to rent from autozone or similar).
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 05-05-2006, 08:31 AM
Thank you Alibi We got the bolt off but not that way sounds easyer than the way we did it. Now the rub.The balancer puller the ones at auto zone don't fit this one has slots no bolts.
Old 05-06-2006, 08:15 PM
spinne1 spinne1 is offline
It will come off with a 6" three claw style puller you can get from most auto parts stores. You don't need to attach bolts or anything, just hand set the three claws around the back of the harmonic balancer with the center bolt close to the harmonic balancer bolt, then tighten the center bolt while kind of holding the three claws to make sure they don't fall off until there is enough tension to keep them on by themselves. It will come off pretty quickly after this.
However, you CAN use a traditional puller for this purpose and there ARE holes big enough for your puller and threads to go in (last I checked anyway). The puller that will work is here:
http://www.autobarn.net/lihabapugm.html
Still, it is cheaper to get the three arm kind and do it that way.
Old 05-06-2006, 09:37 PM
Alibi's Avatar
TNow the rub.The balancer puller the ones at auto zone don't fit this one has slots no bolts.
Huh? Slots no bolts? On the puller or the balancer? The puller will have slots for bolts to go through and thread into holes on the balancer.
A puller should work. looks like this, right? http://www.sears.com/sr/javasr/produ...id=00947626000
-Eric
