Old 05-04-2006, 12:22 PM
Lusitano Lusitano is offline
Help removing the chrome base coat from parts
Hi!
I'm new here, but i have browsing this great forum for some time (and learning a lot!).
I am starting a Revell '69 Charger and stripped the chrome with oven cleaner without much of a problem.
However, the base coat (kind of a yellow-ish gloss coat) to which it sticks is tough as nails and I can't get it stripped either with oven clenar or soaked in brake fluid for a few hours .
I have read great things about CSC as a paint stripper, but it is not available in Europe, where I live. Do you think that it might work in this case? If so, is there any store that ships it overseas?
Sorry if it has been discussed before, but I tried both searching the previous posts and checking the FAQ with no luck.
I hope I can contribute to this community from now on.
Cheers,
Luis
Old 05-04-2006, 02:36 PM
grundski grundski is offline
Send a message via AIM to grundski
Re: Help removing the chrome base coat from parts
What I used very successfully in the past is bleach. Good ol Clorox. It's a lot less messy than oven cleaner. Toss the parts in a jar, cap it wait a day or so and it's all gone.
Old 05-04-2006, 03:12 PM
Jay! Jay! is offline
Horizontally Opposed
+1. Bleach to remove Revell chrome.
Hierarchy of Subaru:
(Click to see mine!)
Old 05-05-2006, 04:35 AM
Thank you very much for your help, gentlemen.
I have placed them in "the bath", so let's see what comes up (or out, in this case
Cheers,
Luis
Old 05-05-2006, 09:10 AM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
I just recently stripped the chrome off a Revell '69 Charger using oven cleaner. Two applications and it was totally clean in a half hour. Look for an oven cleaner with a high amount of lye, seems to be the ingredient that does the work... - Mark
Old 05-05-2006, 11:15 AM
winstona's Avatar
winstona winstona is offline
Easy Off Oven cleaner available in an aerosol spray can is the best! I used it to strip the chrome off my Shelby Cobra 427 and it worked like a charm.
An additional note: The fumes of the oven cleaner does most of the job, not the soaking. You have to spray it all over the model and seal it in a closed box so that the fumes can do its job. Its effectiveness drops immensely if you leave it in open air.
Winston
Old 05-05-2006, 12:14 PM
Wow! Great tips!
I guess my fault with the oven cleaner was leaving it in open-air
Thanks again,
Luis
Old 05-05-2006, 06:50 PM
winstona's point about the fumes is important. I too usually use Easy Off, but have been having good luck with the cheapo stuff from the 99 cents store. I spray the parts in a bathroom sink and cover the sink with an old plastic cutting board. Ziplock bags work well too. I always hold my breath when working with it, the fumes can really attack your mucous membranes. Use common sense... - Mark
Old 05-05-2006, 08:33 PM
bhop73's Avatar
bhop73 bhop73 is offline
409 isn't quite as toxic as bleach and oven cleaner, and works also. See this link:
http://www.childofmecha.com/Modeling/Chrome/Chrome.html
http://www.bhop73.com/
Old 05-07-2006, 09:07 AM
nugundam93 nugundam93 is offline
Blarg! Wort Wort Wort!
try 90% isopropyl alcohol if you can find em. i pick up mine at a local chemistry supply shop, works on a lot of stuff.
olly olly oxen free
Old 05-07-2006, 09:43 AM
joy_ride joy_ride is offline
HEY MAN, i'M NEW HERE TOO. hOW DO YOU POST YOUR QUESTION ON THE FORUM BOARD? I HAVEN'T FIGURED IT OUT YET. iF THIS IS GOING THROUGH, hOW DO YOU REMOVE THE FACE PLATE FROM AROUND THE RADIO OF A TIBURON WITH OUT DAMAGING THE SURROUNDING DASH?
Old 05-07-2006, 09:50 AM
hOW DO YOU REMOVE THE FACE PLATE FROM THE RADIO OF A TIBURON WITHOUT DAMAGING THE SURROUNDING DASH?
Old 05-07-2006, 09:52 AM
joyride, try to turn off your caps lock please.
are you referring to an actual tiburon? please try to post in the hyundai section, there is one.
olly olly oxen free
