Old 07-20-2002, 12:00 PM
dropshop dropshop is offline
Send a message via AIM to dropshop
88-91 CIVIC.CRX rear brake swap info
<B> 4G HATCHES NEED: </B>
90-91 CRX REAR TRAILING ARMS, 90-91 CRX rear brake lines, 90-93 TEG 2dr Ebrake cables
OR
90-93 TEG REAR TRAILING ARMS, 90-93 TEG rear brake lines, 90-93 TEG 2dr Ebrake cables
OR any combo of the 2
<B>2G CRX NEED</B>
90-91 CRX REAR TRAILING ARMS, 90-91 CRX rear brake lines, 90-91 CRX Ebrake cables
OR
90-93 TEG REAR TRAILING ARMS, 90-93 TEG rear break lines, 90-91 CRX Ebrake cables
<B>4DR ED's need:</B>
OR
90-93 TEG REAR TRAILING ARMS, 90-93 TEG rear break lines, 90-93 TEG 2dr Ebrake cables
<B>MASTER CYLINDER INFO</B>
DX: 13/16
HF: 13/16
SI: 7/8
EX: 15/16
ALL FIT ON CRX BOOSTER AND CIVIC
IF U WANT TO USE TEG 15/16
you also need the booster
THE PROP VALVE:
you can use it it helps alittle NOT NECESSAARY
USE CRX 90-91 SI
OR 90-93 TEG NON ABS
<B>MY REAR</B>
<B>MY FRONT</B>
i personally have teg 15/16 and booster w SS lines
FRONT: ITR calipers in front w 11.1 prelude rotors on EX knuckles
REAR: STOCK REAR ARMS w/ 1 90-93 teg rear disk hub spindle caliper and rotor
and 1 91 SIR CRX rear disk hub spindle caliper and rotor
hi im jon and im addicted to boost
Old 07-22-2002, 07:54 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
holy crap those rotors look huge!!!!!
My other ride..... is YOUR MOM !!!!!!
Old 07-22-2002, 08:28 PM
CRX586's Avatar
CRX586 CRX586 is offline
2G CRX NEED
I'm going to do this (rear) soon - will the brake lines and cables from 91 HF work?
What's the difference from a control arm and a rear trailing arm (or are they the same)?
Old 07-22-2002, 10:31 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
you have that info on your site? you want me to stick in the how-to's? that is a common question i get.
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
FS. 88-91 civic/crx b series swap stuff civicracer_1990 Classifieds 0 05-21-2006 01:05 PM
88-91 civic/crx b-series swap stuff civicracer_1990 Classifieds 0 05-21-2006 12:22 PM
2nd Annual 88-91 Civic/CRX PA meet web page is up! CWBETB '71-'87 Civic | CRX 1 03-06-2002 09:51 AM
88-91 Civic/CRX B16 owners: what headers? 13secondcivic '71-'87 Civic | CRX 11 01-10-2002 08:26 PM
