Old 05-04-2006, 10:41 AM
notaricajustfasta's Avatar
notaricajustfasta notaricajustfasta is offline
Send a message via AIM to notaricajustfasta
Engine/Oil Flush?
I got my oil changed today and the mechanics, which I know are rip-offs, said i should get an engine flush and an oil flush. im not sure what an engine flush entails. they said i should do it about once a year for regular maint. should i have these done? thanks.
Old 05-04-2006, 10:47 AM
Cold_Silence's Avatar
Cold_Silence Cold_Silence is offline
Send a message via AIM to Cold_Silence Send a message via MSN to Cold_Silence
Re: Engine/Oil Flush?
I'd say the usual wripoff. Im not sure what it entails but its probably just an oil change and maybe coolant change. You could do both urself, and if u wanted to you could even do a coolant flush, a flush just means you drain it out, chase it with something ie: water to clean it [for coolant], then refill with new stuff.
PS. You double posted, erase the other one :P
The New Ride!! 2002 Cavalier Coupe..
Originally Posted by noshun
It's a lovely 2200, but got about as much poke as my grandma with no fingers.
www.cleanstartsolutions.com
Old 05-04-2006, 11:19 AM
94VL 94VL is offline
Oil flush is probably running some kerosene based solvent thru the oil before changing it.This ruins the oil's lubrication properties and kills the oil boundary layer while the engine is running.Usually an engine will knock or burn oil after using this method.I would steer clear of it.Cavaliers have enough piston knock already,they dont need to add more wear.
Old 05-04-2006, 11:25 AM
http://www.faqfarm.com/Q/Is_a_Gumout...ush_worthwhile
Old 05-05-2006, 10:18 AM
Yea, dont bother.. Could do more harm than good, just keep ur oil changed regularly and it will be fine.
Old 05-08-2006, 12:22 PM
Cavalier2000's Avatar
Cavalier2000 Cavalier2000 is offline
Banned
used some gummy remover stuff on my wife's car last week and it finished off the rear main seal for me. so nice of it
