Old 05-04-2006, 10:00 AM
Ogre1 Ogre1 is offline
Limits on size of wheels and tires
'99 GP Lowered ~1.6". I want to put on some 18" wheels. What is the limit on width of rims and size of tires before I will be rubbing? Still lookin for the rims.
Old 05-04-2006, 03:24 PM
MIKES3's Avatar
MIKES3 MIKES3 is offline
Re: Limits on size of wheels and tires
18s will work. Double check this but you should be alright with 245 width. If I were you get some power adders before you install the 18s. They slow you down quite a bit
2004 GTP
3.2 MPS, FWI 9 inch K&N, ZZP motor mounts mandrel bent 2.5 inch exhaust w/ flowmaster 40s, resonator delete, 3" DP w/o CAT, MSD coil packs Autolite 104s, Autometer Boost Gauge, DHP Power Tuner, S&S Ceramic Costed Headers, W-BDY Store STG III IC, Hawk PADS Power Slot Rotors, 1.8 Roller Rockers, 90lb Springs, LQ4 MAF
14.5 stock w/ 2.2 60'
Old 05-06-2006, 04:06 PM
KX2000GTP KX2000GTP is offline
245 would be the widest you should go, i had 255 and scrubbed bad. And my car is stock height.
