Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-04-2006, 05:38 AM
TreeFrog's Avatar
TreeFrog TreeFrog is offline
Send a message via AIM to TreeFrog
Exclamation HELP! Oil in coolant overflow AGAIN!
okay i need help!! please please!
less than a year ago my headgasket blew. oil filled up coolant overflow. i replace hg at dealership, and it fixed it. now its doing the same thing!
ideas? someone told me it could be the turbo now, or the oil filter housing.
stock turbo, stock boost, 99 GS-T, 80k miles, manual
no smoke of anykind as of yet.
I found the paperwork. the headgasket was replaced 3,800 miles ago. and should carry a factory warrenty from mitsu for 1 year. i assume.
help
Something new is coming...
Old 05-04-2006, 09:20 AM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Re: HELP! Oil in coolant overflow AGAIN!
There should be a part and labor warranty on the work they did if they installed a bad headgasket. Also if there is something wrong it would just be best to go get it checked out now, intermix is usually tell tale sign of something seriously wrong.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 05-04-2006, 09:40 AM
TreeFrog's Avatar
there is a warrenty ONLY on the part via mitsu. labor is a no go becaues the dealership went out of business. for good reasons i might add
Old 05-04-2006, 09:55 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Time to go somewhere else and have them fix it right this time...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 05-04-2006, 10:08 AM
george536's Avatar
george536 george536 is offline
sadly i do believe your gonna have to have someone else pull the head off. you should make sure it comes with warranty.
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 05-05-2006, 01:06 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Try a compression test to see if that shows anything.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 05-05-2006, 04:49 AM
TreeFrog's Avatar
yeah thats what people are telling me. cause that will tell me if its a cracked block. but i doubt that. i bet 99% its the headgasket. our cars are know for this. and if a shitty mechanic put one in then its prob it. yes i had shitty mechanics work on my car. i didn't know it at the time. but i know they put an english threaded clutch line into my salve, and striped it out. leaving me stranded.
Old 05-05-2006, 01:57 PM
-Josh-'s Avatar
I think they probably meant leakdown test more than compression.
AF User Guidelines
Old 05-05-2006, 03:53 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
An easy way to check it is from a cold start, start the car and go feel the upper radiator hose, if it gets really firm fast then you have compression going into the coolant. There are only a few places oil can get into the coolant, headgasket, cracked head, cracked block, thats it on our cars. Have you checked the oil to see if its milky at all? IMO a head gasket isnt that hard to replace by yourself and it will save you a load and you could put that money towards other mods
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 05-05-2006, 06:55 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
you forgot about the oil cooler. this wonderful little device rocks for mixing the 2 together.
never tried it but i would assume that if you clamped the coolant lines going to it and then unhooked them at the cooler you could start it and check for oil to come out. if it does then your cooler is bad, all it takes is one person cranking the oil filter on too tight.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 05-05-2006, 07:48 PM
ez1286's Avatar
I'm sorry this is totally off topic but are you on the wingedwarrior forum? Someone has the same avatar as you and they have a 91 tsi.
Old 05-05-2006, 07:54 PM
TreeFrog's Avatar
okay you forgot about the oil cooler, oil filter housing, and the turbo.
Old 05-05-2006, 08:22 PM
blk_srt's Avatar
coolant doesnt go through the oil filter housing and I wasnt aware that 2gs had oil coolers let alone coolant cooled oil coolers, I for one do not have one. And thirdly if it was your turbo it would smoke like a mofo
Mods:
Old 05-05-2006, 09:30 PM
ez1286's Avatar
The oil is cooled in the oil filter housing.
Old 05-09-2006, 07:27 AM
TreeFrog's Avatar
okay the verdict is in. its a bad oil cooler. even though according to pr_ricer i don't have one
so not as bad as having another bad headgasket.
problem is that all the oil has destoryed my coolant hoses. i need a new hose kit from to top to bottom for the coolant. any ideas? from the dealership his be a small forchin
