Old 05-03-2006, 10:38 PM
jph2424 jph2424 is offline
97 GP misfire over 2300 RPM
I need help.
I have a 1997 GP, auto trans, 3800 non-supercharged with 187,000 miles.
When I take off from a stop and get up to speed no problem, but when the trans shifts and the RPM's drop down below 2300 and then I give it a little more gas, the engine starts missing and shaking real bad. If the RPM go over 2300 and I give it gas, no problem. No misfire. If i'm on the expressway cruising at 60 MPH and give it some gas to pass someone, it will mis and sputter and shake unless I very gently push on the gas pedal.
I have changed the Maf and throttle control sensors but no help.
What could be causing this?
What should I try next?
Old 05-04-2006, 05:40 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 97 GP misfire over 2300 RPM
search the forums for "trans shudder" or "chuggle". There are multiple threads about this issue.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 05-04-2006, 08:13 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Oh yes, the old chuggle aka fishbite. The effect is the torque convertor clutch (TCC) locking/unlocking.
GM has a TSB out on this problem where it recommends checking out the throttle position sensor (TPS).
Also, in my experiences it can be caused by bad spark plugs and ignition wires. How old are they? And what brand?
Timeslip 08/12/06
AF Community Guidelines
Old 05-05-2006, 01:13 PM
wlkjr's Avatar
wlkjr wlkjr is offline
I had that problem twice and both times it was the spark plug wires. The first time only two wires were replaced and the second time the dealer replaced the whole set. It was under warranty at that time. If your wires have never been replaced, that might be a good place to start.
Replacing the wires also cured my mother's Buick Century for the same symptoms.
97 Grand Prix GT
360,000 miles as of 02-01-09
391 000 miles as of 11-17-11
400,000 miles as of 3-15-13
01 Duramax/Allison
07 G6 convertible
Old 05-06-2006, 10:43 AM
Thanks for the info. i replaced the TSP with no change. I'm going to replace the wires and plugs and see what happens. Stay tuned.
Old 06-20-2006, 11:11 PM
I changed the plugs and wires. No more mis-fire. 190,000 miles and runs great. Thank all of you for your help.
