Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 05-03-2006, 08:52 AM
glennco1 glennco1 is offline
'99 SL2 squeal after start
I have a question regarding a '99 SL2 approx 98,000 miles.
Over the last few days, an interesting squealing has popped up intermittently after starting the vehicle and beginning to drive forward. Below I have described the sequence of events to cause, and stop the squealing. Any help you folks can give would be much appreciated.
1: Start the car.
2: Begin driving forward. So far I have not seen the problem in reverse
3: The care will begin to squeal, coming from under the hood.
4: Stepping on the brakes will cause the squealing to stop, and the squealing will not return during driving.
thanks,
Old 05-03-2006, 12:22 PM
saturnspeed_12's Avatar
saturnspeed_12 saturnspeed_12 is offline
Re: '99 SL2 squeal after start
sounds like the brake wear indicator might be hitting the rotor. the rotor has to be moving forward in order to make it squeal. that is my first guess, so id check the brakes first off.
Ian
Saturn Tuners Club-OH Chapter President
1993 Saturn SC2 rebuild project for dad
1995 Saturn SL2 current daily driver /w a lot of work
2007 Chevy Cobalt injen cai, full lsj exhaust, dc sports fsb, progress springs and rear sway bar, enkei wheels/hankook rubber --*boost in progress
Old 05-04-2006, 10:21 AM
saturnspeed, just saw you signature, sorry to heare about your SL2.
I haven't gotten a chance to look at the brakes yet, but if what your stating is true, I would expect that the rotors would need a replacement due to worn holes that go over the studs. Is that your thought? If your thought is correct, it could also be possible that loose front lugnuts could be causign this issue as well then, allowing the rotors to move from their normal position.
Thanks for your help,
Old 05-06-2006, 03:18 PM
well normally when the brake wear indicator hits the rotor, it can groove it, so rotor replacement might be needed (turning the rotors normally arent worth it because they are thin new). but i would definitely look into the brakes first off.
oh and about my car, it does suck, but i just picked out my new project vehicle which will be a 93 sc2. it will be fun, just sucks losing the first one.
Ian
