Rough Idle?
Just reached 200k, has ran great till now. I've replaced the usual, spark plugs(NGK), distributor cap & rotor(factory), wires(Accel/resistence within range). Had osiloscope hook to it 50k ago, injector pulse with odd, but idled fine. The only other things would be the distributor, injector resistor box, or ecu. I do not believe that they have ever been changed. Figured best to ask around before replacing anything else. Any ideas?
Re: Rough Idle?
Re: Rough Idle?
Only dianostic was 50k ago, all new accessories install within last month. As for my concern with ecu & irb, was reading from
injectors during dianostics. |
Re: Rough Idle?
u should also check vac lines and hoses... i had a bad PCV from the breather chamber (caused it to idle rapidly from 1500-2500) thx,Lo
96 civic coupe... bomex front kit + wide bodykit, lowered 2 in, no wheels, (wrecked! sitting in my driveway waiting for me to fix her)92 civic cx hatch... lowered 17z, d16y8 w z6 tranny and p05 ecu... .http://www.cardomain.com/id/showcivic96ex 2007 honda FIT brand spanking new 1993 honda del sol Si just got it (july08) and she was beat up pretty bad [email protected] |
Re: Rough Idle?
Well, problem is that it idles to low, to the point of "almost" stalling. Checked all vacuum lines, had small leak in dashpot line, but only idles high when removed. So no luck with it being something simple, also PCV good. What next? Doesn't smoke at all, just replaced timing belt and tensioner, and yes timing marks were correct. Checked distributor ignition timing not to long ago, so shouldn't be out. Don't own timing light, will try to borrow one tomorrow, and double check.
Re: Rough Idle?
Is there nobody else with any ideas? So the ecu / i.r.b. should either work or not work at all, but does the contacts on the distributor not get worn?
Re: Rough Idle?
Well, only one other thing I could think of to check, and that was the IACV, but no luck there either. Resistance was 11.5, within range, and looks functional. Maybe its just time for a rebuild.
