Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 05-02-2006, 04:39 PM
Toolwise Toolwise is offline
94 Question
I was wondering where the fuel lines were. I know they're metal, but I can't make them out from anything else. So what side of the engine are they on? Where are they in relation to the oil filter? Which one is the inbound line?
Old 05-02-2006, 07:13 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
Re: 94 Question
what engine and which fuel injection system? there are two engines and four fuel injection systems. see this link for more info:
http://www.autozone.com/servlet/UiBr...3d8018bbfd.jsp
why do you need to know? having a problem?
Old 05-02-2006, 08:35 PM
Joshua M. Smith Joshua M. Smith is offline
Send a message via ICQ to Joshua M. Smith Send a message via Yahoo to Joshua M. Smith
Re: 94 Question
Or you could locate the fuel rails and trace them.
Your best bet probably is to get a manual... it will tell you about the pressure line, return line, vapor line, charcoal cannister (if equipped), etc.
Josh <><
1989 Chevy/GMC "Blimmy," 4.3 motor, the only motor I've ever had that I've left stock
1993 Olds Bravada with the works.
My firearms board, in association with Hipowers and Handguns.com:Click Here
Old 05-02-2006, 08:52 PM
Re: 94 Question
94s have the 4.3L Vortec 4300 V6 with Central Port Fuel Injection
Old 05-03-2006, 06:39 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 94 Question
Both the supply and return lines enter the intake manifold at the rear/drivers side. That's also where the fuel pressure checking valve w/black plastic cap (Schrader Valve) is located and it's mounted on the supply line.
Old 05-04-2006, 01:39 PM
Re: 94 Question
Thanks Chris, but since I don't really feel like running out to my car right now, can you be more specific? Like do they connect at the top or bottom of the engine? Do they have any markings or anything to help me tell them apart from all the other metal tubes in there?
Old 05-05-2006, 07:24 AM
AF - Advisor
Re: 94 Question
The intake manifold is made of aluminum and is on the top of the motor. The back side of the intake manifold on the drivers side has the fuel lines I described. You'll have to look between the intake manifold and the back wall of the engine compartment...also refered to as the firewall.
Old 05-05-2006, 11:31 AM
Re: 94 Question
thanks
