Old 05-02-2006, 11:12 AM
berniescout berniescout is offline
wiring harness 97 blazer
last week when doing a tune up on 97 blazer I noticed two red wires which are unattached. Both are red and are located near the brake booster. One is the fuel pump test wire, it has a female blade connector on it. the other one is the ?????. It is about a 14 ga wire with a ring crimp on. red also. what is this wire for??
Old 05-04-2006, 01:38 AM
OverBoardProject OverBoardProject is offline
Banned
Re: wiring harness 97 blazer
Unless your blazer is loaded it's probably just for another option. They usually use the same wire harness for everything.
Old 05-06-2006, 12:34 AM
spano spano is offline
I wonder if that's the wire I am looking for that will supply power to the trailer hitch wiring? Do you have the towing option? Is the rat tail under the bumper wired in to tow? Finally is your RED at the terminal hot in the back if you tie it in, and if you ground it and ohm it do you have a connection? If so let me know EXCATLY where the wire is located. Thanks
