Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-02-2006, 02:07 AM
steviek's Avatar
steviek steviek is offline
Intricate Knowlege of 16g needed
Does any know the diameter of the oil line inlet on the 16g turbo...
Cause I bought the install (2g for 16g) kit from EX PSI and it came with a banjo joint (oil inlet to fuel line) that I'm 99% is not made for my turbo. The first give away was that it was too big to even fit in the inlet and the second was that even If It did fit it would never be able to tighten because it is too long and hits as you would tighten. The beveled side does fit into the provided oil line but I would expect that is standardized. I have noticed that they sell what they call AN -4 bolts double male (in the turbo accesories section) for 8 bucks which is what I think I need (now that the banjo joint they provided won't fit) but before I ordered I just wanted to ensure that when I call to order they have the right size (As well as me).
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 05-02-2006, 02:18 AM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: Intricate Knowlege of 16g needed
call them, I doubt there was a mistake as that kit comes with a shitload of fittings, but they will tell you what you need to do. If they did make a mistake I'm sure they will ship it ASAP
now - 2000 civic
soon - 2002 is300
Old 05-02-2006, 02:22 AM
steviek's Avatar
Many fittings, but to each its own task, So I don't see how it would affect them putting one wrong banjo bolt in amongst 40 other trinkets.
Everything else is good... So I'm not saying its the wrong KIT just one wrong piece
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 05-02-2006, 02:27 AM
kjewer1 kjewer1 is offline
AF - Advisor
he banjo bolt should be M12x1.25 for tdo5 cartridges and 1.50 for tdo6 cartridges.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-02-2006, 02:37 AM
steviek's Avatar
Thanks kevin! ... Now for someone who knows nothing about how bolts are measured do you think you could elaborate on the M12x1.25 a little bit. just so I can measure my kit bolt and compare.
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 05-02-2006, 06:08 AM
AF - Advisor
M12 is the diameter, 1.25 is the pitch. The stock O2 housing's downpipe studs are also this thread, so if your downpipe nut will thread on you know that's it. If the bolt you have is too big in diameter to fit through the feed line banjo fitting, it's almost certainly a coolant line banjo bolt.
Kevin Jewer
Old 05-02-2006, 09:31 AM
steviek's Avatar
That helps a ton. And yes thats the size of the inlet on my turbo.
However, there is no place that that banjo bolt will go on my turbo it isn't for the water line either. It is misplaced IF I knew how to load on pictures I would show you.
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 05-02-2006, 09:38 AM
steviek's Avatar
As a point of interest this would be a sufficient replacement correct?
http://www.extremepsi.com/store/cust...cat=336&page=1
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 05-02-2006, 10:32 PM
AF - Advisor
The list the 14b, 16g, and 20g as using the same bolt, so I already do not trust them on this topic Call them up and get it sorted out.
Kevin Jewer
