Old 05-01-2006, 02:45 AM
bcampbell bcampbell is offline
how do you know if the hub is bad?
how can you tell if the hub is bad?
i'm trying to figure out what is causing my car to drive so bad.
any other suggestions on what i could check would be appreciated!
Thanks
Old 05-01-2006, 07:42 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: how do you know if the hub is bad?
First of all what year is the car and how many miles? What are the symptoms that you are experienceing? If the hub is bad you will usually hear a noise from the bearing when you are moving. If you turn the steering wheel one way or the other the noise usually goes away. A lot of times the ABS light will come on indicating a bad abs sensor which was damaged when the wheel bearing went out. If there is a wobbling or if it feels like loose it could be a ball joint, tie rod end or a control arm bushing. You need to check them all and on both sides. Good Luck!!
Old 05-01-2006, 08:34 PM
wlkjr's Avatar
wlkjr wlkjr is offline
Mine had an extremely loud roar kinda like mudgrip tires on pavement but louder. The noise subsided when I turned hard either direction. I couldn't tell that the handling was off but it did seem to drive better when I put new bearings on both sides.
97 Grand Prix GT
360,000 miles as of 02-01-09
391 000 miles as of 11-17-11
400,000 miles as of 3-15-13
01 Duramax/Allison
07 G6 convertible
Old 05-03-2006, 03:24 AM
Thank you, would any of these things make my trac light come on?
what about a bare metal grinding sound or more like random vibration that I can feel in my foot pedals?
It's also been making that tire rubbing sound and it's getting louder, feels like it wobbles and also feels like a back tire flat on the highway.
98 gt with 138k miles.
it doesn't do that at all so i can eliminate that one. it did have an axle seal? leaking a little bit a while back but nothing was ever done to it.
Old 05-03-2006, 06:17 AM
Pontiac Guy
Yes this will make the trac light come on. If the noise is getting that bad you need to get this changed asap or it is going to leave you sitting along the road.
Old 05-03-2006, 10:02 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I agree with GTP Dad (Lynn), you have classic bad hub symptoms. Teh ABS wheel speed sensor is part of the hub, that's what triggered the trac off light to come on. The change in noise as you turn is another indicator of a bad hub. The sound the bad bearing makes will change as the load is increased/decreased while turning.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 05-03-2006, 11:00 AM
wlkjr's Avatar
I think he said he does not have this indication. But still sounds like a bearing.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 05-03-2006, 02:39 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Just FYI:
I believe BCampbell is a she. She's had problems going back several months on her 1998 Grand Prix. A lot of the problems sound the same to me. I recall she was informed in the past to have her hub/bearings checked out and/or replaced. She's had braking issues, suspension (upper strut mounts/bushings), front end, trac, something about loose subframes bolts and who knows what else.
One such post goes back to 8/2005 entitled Front End/Trac.
Timeslip 08/12/06
AF Community Guidelines
Old 05-04-2006, 07:19 AM
wlkjr's Avatar
Originally Posted by bnaylor3400
Just FYI:
Thanks Bob, and my apologies to BCampbell for my error.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 05-05-2006, 10:38 AM
JstCloseUrEyes JstCloseUrEyes is offline
Bob,
A while back I came here and with the symptoms I was having, was told that I had a bad hub,
but after reading this, I'm not sure
going straight, there is no sound(s)
When I make a right turn, there is a hissing/rubbing sound (definitely not the tire however) coming from the driverside front wheel.
Offhand i dont remember if it does it when I make lefts as well, but definitely right turns
There is no, Traction light, or ABS light on, the car rides fine, and there is no other problem
Any ideas gentlemen and ladies?
2000 GP GT ~ Super Turbo Mufflers ~ Custom Dash ~ Owned by Poor College Student ~ Not Much Else Done ~ Saving for WS6 :-D
Old 05-05-2006, 11:09 AM
BNaylor's Avatar
Originally Posted by JstCloseUrEyes
Bob,
Hard to say but it could still be a hub/bearing most likely on the driver's side. They don't necessarily give off noise like grinding, roaring, etc. or a trac or abs light.
You could run some tests which will require jacking the car up, removing the wheel and the disc brake caliper. Hub wear tolerances are pretty tight. After removal of the caliper you lock down the disc rotor by securing with the lug nuts. Then grab rotor at various positions such as 12/6 o'clock and 9/3 o'clock and pull out. Another suggestion is to check the preload on the axle nut. If you still have the GM OEM hubs the torque value is 151 ft-lbs.
If the hub has any slop or wear the noise you are hearing could be the rotor against the pads when there is a high "G" situation such as turning. The rotor is attached to the hub and secured with the wheel and lug nuts. Torque value 100 ft-lbs.
It is worth looking into and won't cost that much versus buying a hub and finding out it didn't fix the problem. Good luck!
Timeslip 08/12/06
Old 05-05-2006, 11:14 AM
richtazz's Avatar
JstCloseUrEyes, a bad hub will not always trip a Trac-off/ABS light. Since the wheel speed sensor is contained in the hub, it very often does, but not always. The symptoms you describe points to the hub as the culprit, as hub bearing will get noisier when unloaded. Since the noise comes from the left side while turning right, that would finger the left front hub as the guilty party.
