Old 04-30-2006, 07:35 PM
newfdude newfdude is offline
Unhappy holley carb problem
hi guys just put akit in my holley carb set the floats as per specs started car starts good idles great road tested thats when she started to flood bad gas was running out of the vent all over the carb you can see gas running in carb wont start now any help would be great thanks ps i also replaced the power valve
Old 05-16-2006, 12:23 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: holley carb problem
I'm sorry I did not see this earlier.
It sounds as if your float (in the float bowl) has become flooded and has sunk. Install new floats in both the primary and secondary sides.
Old 08-23-2006, 07:05 PM
Smile Re: holley carb problem
hi magicrat just want to say thanks the new floats worked great
Old 08-23-2006, 11:42 PM
MagicRat's Avatar
I'm glad to read that! You are welcome.
