Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 04-30-2006, 04:11 PM
brainyass's Avatar
brainyass brainyass is offline
Brakes and brake pedal pulsates
1997 GC, When ever I brake, it feels like the ABS is acting up and making the whole vehicle and brake pedal pulsate. I thought it was a warped rotor, replaced rotors and pads, same problem. It just feels like I'm pumping the brakes and the brake pedal moves up and down when braking. I wanted to make sure it wasn't the rear brakes so I pulled the ebrake and put on the gas. nothing pulsated until I used the brake pedal again. Help would be greatly appreciated. Thanks!
Old 04-30-2006, 05:33 PM
JDPascal JDPascal is offline
Re: Brakes and brake pedal pulsates
To eliminate the ABS from the possible causes, go into the power distribution center by the battery. There is an ABS pump relay and an ABS system relay. The positions should be marked on the inside of the cover. Pull them and do a test drive. The ABS will be disabled and you will still have the regular power brakes. Any "badness" remaining in the brake operation will be from the mechanical part of the system. If the pulsation has cleared up, need some more info and checks done
JD
If ya can't fix it right the first time, how ya goin ta find the time ta fix it again????
