Go Back   Automotive Forums Car Chat > Renault > Clio/Clio II/Clio III
Old 04-30-2006, 05:23 AM
dwp40 dwp40 is offline
Leaking sunroof
The manual sunroof on my 02 clio has started leaking, it seems tp be coming in around the locking mechanism, anyone had similar problems and if so how did yo go about fixing it??
Old 07-30-2006, 01:04 PM
clio22 clio22 is offline
Re: Leaking sunroof
My clio also has a leaking sunroof. (It is a known fault with clio's!). The only succesful solution that i found to stop it is to try find the area it is coming in... around the seal usually, then apply vaseline generously to the seal before closing the sunroof up and this forms a tight seal which prevetented it from further leaks!
Hope this help
Craig
Old 08-16-2006, 02:45 AM
ZOE2's Avatar
ZOE2 ZOE2 is offline
Re: Leaking sunroof
My Clio Leaked On Saturday When Had Bad Rain And Also Leaked On My Old Clio.its A Very Common Problem With Clio's. On Sat My Central Locking Stopped Working As Water Got In Above The Sensor.once It Dried It Staring Working The Next Day. If It Is The Same Place As Mine.take Sensor Out Or The Interior Lights In Just Add Some Good Sealer Around The Top In Inside To Stop Water Coming In. Hope This Is Any Use
Old 11-17-2006, 10:55 AM
seraph boy's Avatar
seraph boy seraph boy is offline
Cool Re: Leaking sunroof
My mate had one and couldn't fix it had to go, must be a problem with the 02 and previous.
Old 11-28-2006, 12:09 PM
jijclio jijclio is offline
Re: Leaking sunroof
i had the same problem with my 1996 clio. What i did was clean the sunroof gutter and the water just flowed down through the leak of valve and out under the car.
Old 11-28-2006, 01:56 PM
seraph boy's Avatar
Re: Leaking sunroof
I didn't think of doing that and that might have solved the problem but now he has gone for the nissan micra, not the most suited car to a boy. Thanks for the advice.
There are two loves i have of cars,
  1. Porsche's
  2. Rolls Royce
Especially the Porsche Cayman s. Not that i have expensive taste at all!
Old 12-21-2006, 10:46 AM
NazeDef's Avatar
NazeDef NazeDef is offline
Re: Leaking sunroof
Yup i had the same problem on my Clio S Maxim 97. Leaked thro to my immobiliser and cudnt use it for ages. Had to wait for it to dry out then what i did was apply vaseline round all of the seal really generously, closed the sunroof and put black duck tape round the edges on top. Its been fine ever since. This is only for the winter though i gotta open it up for the summer when it comes lol but yeh this is a known problem with Clio's everyone has them i think.
''But Then If You A Liar Liar, Pants On Fire, Wolf Crier, Agent Wit A Wire, Im Goin Know It When I Play It'' **Dead Prez**
