Old 04-29-2006, 10:45 PM
TransAm87 TransAm87 is offline
2.73 or 3.23?
So I was on a site looking up engine specs and I noticed that gearing for the automatics has a standard option(2.73) then theres another option(3.23) so just wondering how do I know which gearing my car is set up for? Now I noticed the board has been dead lately so I'll wait a while for some answers..and if that fails I'll just ask on the camaro forum
Old 04-29-2006, 10:50 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Re: 2.73 or 3.23?
Check your drivers side door for your option codes.
If you see GU5 that's a 3.23 car and a 3 series carrier. If you see GU2 it is a 2.73 car and a 2 series carrier. Know what it is before you switch gears because the new gears will be carrier specific.
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 04-29-2006, 11:00 PM
Re: 2.73 or 3.23?
hey that was quicker than expected..but I checked the sticker on the inside of the door and all im seeing is tire pressure, weight info, etc.. I'm not seeing any codes like that, but i'll look again..
Old 04-29-2006, 11:10 PM
Mr. Luos's Avatar
Firebird Guy
Re: 2.73 or 3.23?
Right here....
Stock'ish'
Old 04-29-2006, 11:15 PM
Re: 2.73 or 3.23?
I see, well theres my problem then, i don't have a service parts id sticker, all right well thanks I'll have to find out some other way
Old 04-29-2006, 11:18 PM
Mr. Luos's Avatar
Firebird Guy
Re: 2.73 or 3.23?
At WOT what MPH does it shift outta first at??
Stock'ish'
Old 04-29-2006, 11:59 PM
Re: 2.73 or 3.23?
i'll have to get back to you on that one, it's been a while since I've really opened the car up, its been raining a bit and all so as soon as I have the chance I'll let ya know..
Old 04-30-2006, 10:35 AM
76ta's Avatar
76ta 76ta is offline
Send a message via MSN to 76ta
Re: 2.73 or 3.23?
i know to check mine [second gen] and a friends 3rd gen camaro, u crawl under the passeneger side of the car by the rear diff, and on the top front part of the passenger side axel housing close to the carrier, it has the code stamped into the housing.. mine need to wire brush it a bit to get the code visible, then check ur haynes manual
76ta
Old 04-30-2006, 02:55 PM
doodad's Avatar
doodad doodad is offline
Send a message via AIM to doodad Send a message via Yahoo to doodad
Re: 2.73 or 3.23?
drive it up to 80 mph and floor it and if it downshifts to 2nd gear that means you got 2.73 gears.. my point is, 2.73 grears downshift almost at many speeds but 3.23 gears dont downshift as much as 2.73 gears do.
Erdal
Old 05-01-2006, 08:21 AM
m2g4b m2g4b is offline
Send a message via Yahoo to m2g4b
Re: 2.73 or 3.23?
hey there, also you can look in your glove box and you should have a sticker there as well with all the codes on it.....i didnt have one on my door either, but it was in the box.....i am lucky and got a car with the 3.23 gears!!!! good luck!!!!
Old 05-02-2006, 04:19 PM
DarkblueTA's Avatar
DarkblueTA DarkblueTA is offline
Send a message via AIM to DarkblueTA
Re: 2.73 or 3.23?
After you run it up through the gears a bit...if you shift around 60mph, you have 2.73s. around 45-50, you have 323s.
DarkblueTA
GT70, FMIC, Alky-water injection, Hooker Cat back, 208/230 .549/.579 121LSA Cam, forged diamond pistons/eagle rods, LS6 block, Lakewood LCAs, BMR STB/PHRB/Sway Bars, poly torque arm bushing, Spec Stage 4i clutch, B&M Ripper Shifter, SLP Subframes, 60# injectors, KYB AGX shocks/struts, Moser 12 bolt(373 gears, 33 spline axles, posi, ta girdle/etc/etc/etc) and HPTuner kit
2007 Nissan Titan Daily Driver. 2* advance
Old 05-03-2006, 12:25 AM
doodad's Avatar
Re: 2.73 or 3.23?
what do you mean?? when you floor it, if it shifts on 45-50mph he got got 3.23s. if it shifts on 60mph he got 2.73s?? is this at the first gear?? are you sure that is correct?
when l floor my car, it shifts at 47-50mph to second and then right on 90mph to third and l dont know which mph to fourth because of the speed limiter.. and l think l got 2.73s.. am l right??
Old 05-03-2006, 10:31 PM
Re: 2.73 or 3.23?
okay, well first of all i have no parts sticker in my glovebox so as far as I can tell there is no easily visible parts identification on my car, anyway I took it out tonight for a drive and opened it up, not too hard but enough and i noticed a few things, I don't know what speed it shifts out of first but I did find that the car changed shifts at 45-50 and 60 mph, and it also downshifted at 80, so as far as I can tell I have 2.73's, I'm still not completly sure but I'm gonna look up some more ways to find some parts id on my car and maybe take it out again for some more hard driving
Old 05-04-2006, 05:14 AM
DarkblueTA's Avatar
Re: 2.73 or 3.23?
Bingo was his name o.
Nope, you should have 323s. Unless your transmission gearing has been changed. Then again, I don't know what year car yours is but if you have a 3rd gen and are shifting before that, you may have 3.08 gears(drum brakes are a dead giveaway with this) and 273 geared 3rd gens came with disc brakes(if my memory serves me correct.
DarkblueTA
Old 05-04-2006, 08:49 AM
doodad's Avatar
Re: 2.73 or 3.23?
My car is 4th gen. 1997 LT1 formula.
