Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 04-29-2006, 10:14 PM
4PROSALES 4PROSALES is offline
96 Suburban 2500 7.4 Hesitation
My Question is where is the Fuel Pressure Regulator Located on my 96 Suburban 2500 7.4 ?? I would like to replace it. Also I Cant find the Fuel Filter for the same vehicle. I spent some time under truck lookin for gas line or filter any help Greatly Appreciated.
Jim
Believe it or not I'm very mechanically inclined Just ignoranr with this vehicle!!
OK New Plugs, Rotor, Cap,Wires, Fuel Filter, precious owner New Fuel Pump installed. Hesitates when I start to drive away. If i hold the gas peddle just barely to go with out increasing throttle it hesitates stutters..throttle Position sensor ? Fuel Pressure Regulator? Just take it to a GM DEALER $$$$$ OUCH!!
The check engine soon light came on after I replaced the Fuel Filter Went Off Came on Later went Off..O2 Sensor ?? EGR Sensor ?? smelled like gas when I was hooking up the trailer and the Suburban was running..Like Rich Gas ?? any help appreciated
Thanks
Jim<<>>
Old 05-14-2006, 06:36 PM
Igovert500's Avatar
blue + red light magnet
Re: 96 Suburban 2500 7.4 Hesitation
moved it for you, here you'll get more replies
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 05-14-2006, 07:39 PM
777stickman 777stickman is offline
Fuel filter is located on the drivers side frame rail close to between the drivers door and the rear left door. The fittings are metric on both the lines and filter. SAE will work, but be careful. Fuel press reg i'm not sure about. My '98 manual says to take the upper intake plenum off for access. Doesn't show a picture. It's on the fuel rail back there someplace. Has a vacuum line on it. Hope this helps and welcome to the forum..............Steve
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 05-15-2006, 06:03 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
It may be in upper plenum. Book time over 2 hrs labor.
Look at top of engine and if you can see fuel rail on each side and injectors it should be on fuel rail. If you do not see the fuel rail and injectors it is inside upper plenum.
MT
MT
Old 05-17-2006, 07:46 PM
Boomyal Boomyal is offline
It seems to me that both responses are for MPI Suburbans. I believe your '96 454 is a TBI model. I do not know the location of the fuel filter but I am sure that it is different than the later MPI Vortec models!
ps, I doubt the filter is the cause of your hesitation. I have a '94 454 TBI and it still has the original fuel filter, where ever it is located.
Old 05-17-2006, 09:54 PM
MT-2500's Avatar
AF - Advisor
That might be because the 96 7.4 2500 J engine is MPI.
If you fuel filter never has been changed on yours it is about time to have a look at it.
And they all put them in the same old place. Frame mounted under drivers seat area.
MT
MT
