Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-29-2006, 09:01 PM
bl1tzk1213g bl1tzk1213g is offline
oil loss
I had my oil change less 500 miles ago and it was over the 2nd line on my dipstick, now its below the first line. I ran it hard couple of times. Could it be my turbo? I had my sister video tape my exhaust at idle while I rev at it. I saw some bluish smoke not very much though.
Another question, how come my clutch sometimes losses pressure. Most of the times when I go to school in the morning when my car is just sitting for a period of time. Sometimes while driving too. I have to pump my clutch I'm guessing I need to bleed it
1997 Mitsubishi Eclipse GS-T 5spd stock ?
Tsudo 3" catback
Bomz Intake
HKS SSQV BOV
bcs mod and a useless boost gauge
Old 04-29-2006, 09:30 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: oil loss
Could be turbo or piston rings do a compression test just to see. For the clutch it sounds like you either have a bad slave or master cylinder. It's not a bad idea to repplace both. You can also go for ss lines someone (roadrace maybe) makes a full ss clutch line (master to slave) for $100. Master and slave together are about $120 from rockauto.com.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 04-30-2006, 05:29 PM
rckrz6 rckrz6 is offline
Re: oil loss
can also be bad value seals (caused my burning oil)
Old 04-30-2006, 10:49 PM
ez1286's Avatar
Re: oil loss
Yeah thats true, even easier to check for. Just take off the oil fill cap while it's idling and feel if there is a lot of air blowing out, if so it's bad valve stem seals.
Old 04-30-2006, 11:21 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: oil loss
find out if it happens after you shift, then its probably valve seals
now - 2000 civic
soon - 2002 is300
