Go Back   Automotive Forums Car Chat > GMC > Envoy
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 04-29-2006, 05:47 PM
drummer14 drummer14 is offline
03 Envoy does not start
I have a 03 Envoy that does not start at all, completely dead! I have replaced the battery, checked the fuzes, alternator, starter etc...The funny thing that happens when I put the key in and turn is that the Speedometer and other gauges go crazy. All the other electrical things such as lights, and radio work fine. I also can't put the car in gear to tow it, so I am outta luck. I was doing some post readings and noticed that the ignition switch has been causing similar problems. I have ordered one since both me and the car are in a place that has no GMC dealers nearby. Does anyone know how to test the problem and/or replace the switch?
Thanks
Mark
Old 04-29-2006, 05:51 PM
maxwedge maxwedge is offline
A990 racer
Re: 03 Envoy does not start
How about a Chevy dealer same truck, this needs to be diagnosed with a trouble tree or wiring diagram. Alldata.com has an online manual subscription.
Old 04-30-2006, 06:00 PM
Thanks, the only dealership around is a Ford
Old 05-12-2006, 01:04 PM
dstreet6 dstreet6 is offline
Last night my 02 Envoy did the exact same thing as the original poster. Now it's just completely dead, has a new battery and now the key is even stuck. I can't get it out or put the car in neutral to back it up.
I tried jumping the battery but nothing. HELP!
Is there anything I can do to take the key out of the ignition? Now its just completely stuck... I can turn it to try to start but the car is completely dead. I cant turn it all the way back to get it out...
So the SUV is just sitting in the driveway and I can't take it to the shop to get looked at.
Old 05-12-2006, 02:11 PM
I couldn't believe it, but it turned out to be the ignition switch, about $35.00. I replaced it and it started right up!!! Anyway, I ended up doing the job myself and it wasn't too difficult, it's up to you if you want the dealer to do it. The whole process took me about 2 hours or so. Turning the key on and off, will not help fix the problem...
I bought a Haynes guide and it walked me through the process pretty easily. One I disabled the SRS and took off the steering wheel and column covers, the switch was right there and replacing it was a piece of cake. My key was also stuck in the ignition; once I removed all that stuff, there was a little metal button that I pushed in and the key came right out......Hope this helps
Old 05-12-2006, 05:28 PM
A990 racer
Question Re: 03 Envoy does not start
Good work, took a guess or did some checks to find the problem?
Old 05-12-2006, 07:00 PM
Did research, asked a lot of questions and prayed to GOD!!!!! Luck came from somewhere!!!
Old 11-26-2007, 01:44 AM
ANDYZCO ANDYZCO is offline
Hello, I have this same problem this morning when I put in the key and turn it to RUN position it doesn't start but it turns to that position, it wasn't the battery. its got to do something with my ignition switch i believed!!!...please help if u experienced this problem and had it fixed!!!......
Old 11-26-2007, 01:47 AM
Can u please tell me what brand name of the ignition switch u bought for the replacement?, I have the 2003 GMC Envoy, please help!!!
Old 11-26-2007, 11:59 AM
I fixed it and it works like a champ. I actually bought the switch from a dealer, so I assume it was a factory OEM switch. It only cost about $35.00. If you read my other post, it was fairly easy to do using the Haynes guide. One thing I did discover afterward was ensuring that the teeth in the switch are set to the right position, I had it set one tooth off and it kept the battery power on after I turned off the vehicle. Good luck
Old 11-27-2007, 12:51 AM
Oh great stuff, this morning when my car was still sitting in the lot, I called the deal and they sent the mechanic over to see what the problem was and he figured it out. It was the ignition switch/cylinder block. The connector in that unit wasn't attach to each other so he took everything apart and had it attach it tightly and now the car is starting fine...like u said there is a teeth for that ignition switch, and its gotta be in the right position..Thanks for your info by the way!!!
Andy..
Old 11-27-2007, 07:08 AM
A990 racer
Ok guys this is a year and a half old, thread closed, thanks.
Closed Thread
