Old 04-29-2006, 02:46 PM
C5Longhorn's Avatar
C5Longhorn C5Longhorn is offline
Shocks
I have a '99 Blazer LS 2WD that is my daily driver. I recently noticed I have a leaking shock. Since I have a bad shock I might as well replace them all since I have 93K on the odometer. I'm looking for recommendations of shocks to use and any install tips.
I mostly do street and highway driving. I would like a decent comfortable shock.
Thanks in advance for the help.
Rick
Old 05-01-2006, 09:19 AM
OverBoardProject OverBoardProject is offline
Banned
Re: Shocks
We've answered the same question a few times, so I'll save the debate and just give you some links.
http://www.automotiveforums.com/vbul...ghlight=shocks
The install is usually pretty straight forward, but if you need advice on it please just ask for it.
Old 05-01-2006, 09:26 AM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Re: Shocks
Like OverBoard said, do a search or check the links he provided. In your case though I would go with the most inexpesive shock you can find at like a pep boys or an auto zone. Usually, but not in all cases, the cheaper the shock the better the ride quality under normal driving conditions. Basically soft, so through the bumps or hard cornering you are going to tell you have a cheap shock, but on the highway and regular paved taken care of roads you should have a plush ride. Good luck and post what you buy!
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 05-02-2006, 08:40 PM
C5Longhorn's Avatar
Re: Shocks
Thanks for the responses. I'm probably going to check out some Monroe's or KYB GR2's.
Rick S.
'99 Chevy Blazer LS-Daily Driver - K&N Air Filter
'02 Mil. Yellow Z06-Vortex Rammer, FLP LT Headers, MTI LS1 Edit programming, Kirban Shifter, NGK TR-55 plugs and Taylor 409 wires, MOMO shift knob, Baer Eradispeeds, Ken King Interior accessories, APC headlights and PIAA 1100 Foglights, lowered, !CAGS
Old 05-02-2006, 11:35 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Shocks
Monroes Sensi-tracs will give you a comfortable ride.
I personally installed some cheap heavy duty shocks. They are fine but the ride is a little rough especially with 18s.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 05-03-2006, 06:30 AM
Markgc's Avatar
Markgc Markgc is offline
Re: Shocks
I had some Spax adjustables in the UK. They had a small side mounted screw which let you adjust the amount of damping that you required.
Mark
Old 05-03-2006, 08:57 AM
C5Longhorn's Avatar
Re: Shocks
Any suggestions on where to get the best price on Monroe's? I checked Rockauto but they didn't have the Sensa Trac's listed for a 2wd Blazer.
Rick S.
Old 05-03-2006, 10:19 PM
BlazerLT's Avatar
AF -Advisor
Re: Shocks
Check your local auto-parts stores for stock.
Old 05-07-2006, 01:00 PM
C5Longhorn's Avatar
Re: Shocks
That is what I did. Total out the door including local sales tax was around $150 for 4.
