Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Exterior and Wheels
Exterior and Wheels This is the place for all exterior wheel modifcations.
Old 04-29-2006, 12:37 PM
patoffspyder patoffspyder is offline
Lowering my eclipse spyder?
Hi guys!
I want to lower my eclipse spyder GS 97, but I don't know where to search, so I tried Ebay. There is spring at 15$ (+65$ for the shipping to Canada). I think it's a little bit cheap right? What should I check?
http://cgi.ebay.com/ebaymotors/95-99...QQcmdZViewItem
Are they any good?
Basically, I don't do any track racing with my car, I just want it to be lower. I still can't lower my car much, because where I live, the road are all broken and there is a lot of bumps.
Also, some sellers say that their springs will not fit an eclipse spyder, only a hardtop one. Is there any difference in the suspension between an eclipse spyder and a hardtop one?
Thanks for your help!
Old 04-29-2006, 01:58 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Re: Lowering my eclipse spyder?
There is no difference between the suspension of the hardtops and soft tops. The only difference is the weight. The convertibles are obviously heavier than the hard tops, so a lowering spring for a FWD hardtop may not be able to support the weight of a convertible, causing the car to be lowered excessively. I would suggest buying lowering springs for an AWD GSX because the weight of these cars are closer to that of your convertible. I personally wouldnt buy ebay springs. Eibach springs have a good reputation. Eibachs come in pro-kit, or sportline. Since you dont want your car to be lowered too much I would go with the AWD GSX Pro-kit Eibach springs. I have also heard good from TEIN springs but I really dont know.
The ones in that link are the "slip over" type coilovers that are adjustable in height, I have heard both good and bad about these springs.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 04-30-2006, 10:37 AM
NY91TegOwner NY91TegOwner is offline
Send a message via AIM to NY91TegOwner
ok and sorry to sound like an idiot but when lowering a car do you just need springs or do you need to buy the whole kit with like coilovers and everything or do you just put the springs on and poof its lowered
Old 04-30-2006, 05:38 PM
No you dont need full coilovers. You can drop your car with just lowering springs, but if you are going with springs I suggest that you atleast upgrade your shocks, because the stock shocks aren't designed to be used on a lowered vehicle and they will probably wear out quickly if used on a lowered car. But to answer your question yes you can just install lowering springs and poof its lowered.
Caleb
vanilla gorilla
Old 05-01-2006, 12:18 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Lowering springs are just what the name says, it's a coil spring that is a one-height ride only. Upgrading shocks is a damn good idea too. Coilovers is a coil spring with an adjustable height sleeve so you can adjust the ride height that you want. Cheap coilovers come with just the spring/sleeve combo and expensive coilovers come as a whole suspension piece, spring/sleeve combo and shock.
95 Talon TSI AWD
97 Eclipse GST
Old 05-03-2006, 10:52 PM
Black97GST Black97GST is offline
DO NOT get those coilovers! e-bay coilovers SUCK! your car will be like a damn pogo stick! My buddy has them on his Eclipse and I SWEAR TO GOD, you can feel the PAINT on the road when ever you ride over it! no joke! Do not buy!........... Lowering springs all the way!
Old 05-17-2006, 09:25 PM
Fallenfantasies Fallenfantasies is offline
Dude i had a 98 rs eclipse and bought the cheap coil overs off ebay and slammed mine into the ground man. I mean you could barely even get ur foot underneath and it looked real good man but started causing problems after awhile. if you are gonna do coilovers, then dont forget about struts and DEFINTELY a camber kit. Coil overs eat ur tires like crazy because the hubs cock in. And the struts because your car is not very stiff. My car wasnt really to ruff and my stock struts held but i went to SKunk2 and found a really good set for 200 and I am seriously 110 % more satisfied. They look better and have a better choice of where i want my car from the ground
Old 05-17-2006, 11:06 PM
LOL OMFG!!! thats the best thing i have ever heard. That just might be sig worthy. "i bought the cheap coil overs off ebay and slammed mine into the ground man. I mean you could barely even get ur foot underneath and it looked real good man but started causing problems after awhile." I cant figure out WHY IN THE HELL that would cause problems?? what a retard dude. come on man. You might wanna replace all your bushings and suspension components! and then give your car a good wash, wax, and detail for putting it through that.
