Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 04-29-2006, 11:40 AM
Ramblin Fever Ramblin Fever is offline
EXACTLY which tranny fluid goes into
our auto transmissions?
My owner's manual says Dex-3; however Haynes manual says Dex-2
My shop has used Dex-2 on my tranny over the course of 2-3 fluid change outs; have over 60k on their fluid, i.e. Dex 2 with no problems in shifting, slipping, etc.
So my question is, since I have a very mild leak, WHAT do I put into this tranny? Dex 2 or Dex 3, and are the two compatible with eachother??
FWIW - even if the Dex 2 is the wrong fluid, tranny's shifting wonderfully!
Oh, and I know it's been repeating 10000k times, but can one give me exact/precise instructions on -
1. Checking fluid level, on these no dipstick thingies?
2. Partial drain/refills through add/check fill plugs?
And, should one just barely let the truck idle for 3-5 minutes before procedure's, or can they be performed after doing basic city driving as well?
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 04-29-2006, 01:12 PM
Blue Bowtie's Avatar
Registered Offender
Re: EXACTLY which tranny fluid goes into
Dexron III is completely compatible with transmission applications specifying Dexron II. Some other applications that specified D-II (like some power steering systems) may have a little trouble with the D-III, but transmissions should be fine with it. Version IV may be incompatible, so don't go there.
http://www.google.com/search?hl=en&l...22&btnG=Search
Old 04-29-2006, 01:19 PM
rodeo02 rodeo02 is offline
DexII probably wouldn't harm your 4L30E, but that is an out dated ATF. Use Dexron III or any Mercon/Dexron III universal ATF will be fine & is your most common off the shelf ATF.
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 04-30-2006, 07:24 AM
surferfletch surferfletch is offline
III.
I edited this before, I thought.
