Go Back   Automotive Forums Car Chat > Buick > Riviera
Old 04-29-2006, 01:16 AM
84accord 84accord is offline
Security Light On '97 Riv, Rapid Flash...
The security light on the instrument cluster of my ’97 Riv is acting weird.
At random times, it will flash at a rapid rate and the radio will stay on after the key is removed and a door is open. With the rapid flashing a relay under the rear driver side seat can be heard cycling at the same rate as the security light.
Anybody seen this before? What is the cause?
Thanks,
Rivrocket
Old 04-29-2006, 10:35 PM
96riviera18 96riviera18 is offline
Re: Security Light On '97 Riv, Rapid Flash...
i havent heard of that happening b4 but you may want to check the door latches to make sure there isnt a lose latch or connection thats the only thing i can think of that may keep the radio on and the security light on. you may want to check the battery too b/c all kind of wierd things can happen when one is on its way out.
Old 05-07-2006, 02:03 AM
I might have found something. I turned my 97 Riv off while stopped but with the transmission in drive the other day. When I got out of the car the problem was gone.
Coincedence??
