Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 04-28-2006, 11:22 PM
papiichuulo papiichuulo is offline
AF Premium User
delayed a/c operation?? 10 min. after startup!!
Anybody have any ideas? I have an 03 crown vic intercepter with a new problem for me. On a cold start, the a/c clutch doesn't engage until about 10 min. later, then the a/c begins to cool. I have not run into this problem before, plz help!
Old 04-30-2006, 08:34 AM
fleettech fleettech is offline
Re: delayed a/c operation?? 10 min. after startup!!
swap the A/C relay out with one of the others (cheap test) We have had a bunch of them act like that and most of the time its the relay going out
ASE Certified Master Auto and Medium/Heavy Duty Truck Technician
Master Certified Emergency Vehicle Technician Law enforcement Vehicles
Old 05-24-2006, 10:41 PM
AF Premium User
I already tried that, it didn't work. Any other suggestions? Do you know of any ways to test the high and low side cycling switches?
Old 05-24-2006, 10:45 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Maybe your low on refridgerant, and when the system gets heated up, the pressure increases enough to kick on the compressor.
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 05-25-2006, 07:58 AM
AF Premium User
pressure is good when the system finally kicks on.
Old 05-25-2006, 01:19 PM
The PCM controld A/C operation, so checking for trouble codes would be a good thing to do. Even if the check engine light is off, codes may be stored. A cheap autozone scanner may not be able to pull all the codes, but a good snap-on or dealer scanner will. You can also perform tests on the system with a good tool. I'd avoid probing around on the a/c system. You run the risk of feeding back high voltage into the PCM.
Old 05-25-2006, 02:30 PM
AF Premium User
u r right, i should have thought about that. I hope the nemisys from otc will do the job. I will look into that and let you know what happens, thanks!
Old 05-26-2006, 12:40 PM
AF Premium User
Good call!!! The little nemisys pulled a P1462 code, a/c press sens circuit low input. hhmmmm......
AF Premium User
Old 06-12-2006, 11:33 PM
AF Premium User
I hate it when that happens..... the codes did absolutely nothing for me. It turned out to be a temperamental friggin relay. It worked when it felt like it. When I checked it the first time around it didn't make a difference, this time it fixed it.........aarrrgggggghhhhh!!!!!!!!! LOL
