Old 04-28-2006, 07:59 PM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Ignition coil questions
Are there any performance differences between the Magnavox style coil pack and the type II ignition coils? Can a magnavox coil pack be replaced with the type two coils? Reason I ask is because MSD makes performance coils for the type II ignition coils, but not for the Magnovox type. The firing order is the same for both, so I thought they could be interchangable, just thought I'd check first. Thanks!
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 04-28-2006, 08:51 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Ignition coil questions
Yes, the Magnavox can be replaced with the Delco ignition system with three coils. If the replacement unit is of the same vintage, the wiring harness should hookup to the Delco unit without any problem.
A good link on the subject;
http://www.thejmfc.com/autos/delcoignition.html
Old 04-28-2006, 10:20 PM
Loekee75's Avatar
Thanks Hotz28. Any noticable difference with the MSD coils and wires in your Ultra?
Old 04-29-2006, 01:14 AM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
I did not know you could do that....I am curious also, does it give anymore power? If so, then I know what I'm picking up next time I'm at the pick and pull junkyard...
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 04-29-2006, 08:38 AM
HotZ28's Avatar
AF Moderator Elite
The Delco unit has several advantages over the Magnavox. First, the coils are higher voltage (30K) vs. (20-25K) and independent of the ICM. (They can be replaced individually). The Delco system was initially used as a factory upgrade from the Magnavox, and is still being used in some cases. Second, long term reliability, has proven better on the Delco system. (The Magnavox unit was prone to moisture related failures). Finally, the individual parts are cheaper to replace than the complete Magnavox unit. I.e. ICM & coils.
I did notice a change in performance when I changed to MSD coils & wires. Smoother idle and instant throttle response were just some of the benefits. WOT was also improved!
The MSD coils are rated @ 40K Volts vs. 30K for the Delco. I have heard of MSD coil failures after about two years, however, I installed mine about two years ago and they are still working fine. I guess time will tell. All three cost about $120.00, or $40.00 ea, so replacement of one, or all, is not an issue for me. The standard warranty is one year.
Spark plug wires are very important to the operation of your DIS ignition system. A good quality, helically wound wire and proper routing are beneficial to getting the best performance from your ignition. MSD uses a Heli-Core & 8.5mm Super Conductor Wire. Helically wound wires provide a good path for the spark to follow while keeping Electro Magnetic Interference (EMI) to a minimum. The wire set I use is part #32789, listed in the catalog for the Pontiac Grand Prix 3.8L Supercharged 1997-2000
The links below will give you more info;
http://www.msdignition.com/coil_blaster_9_8224.htm
http://www.msdignition.com/1sparkplugwires.htm
Old 05-08-2006, 11:25 AM
Cntrysthbst Cntrysthbst is offline
Send a message via Yahoo to Cntrysthbst
How do you tell the two apart? And do you switch the ignition module as well? I have the type two ignition system, all plugs on right side of coils. Thanks!
Old 05-08-2006, 11:28 AM
Can I test the voltage output on the packs I got now with a volt meter? and which setting do I use if so? Thanks again!
Old 05-08-2006, 11:51 AM
Loekee75's Avatar
Sounds like you have the "better" coil/ ICM pack we were talking about, cntrysthbst! The other is a coil pack with the contacts on both sides of the housing.
Old 05-08-2006, 01:17 PM
10-4. Do you know how to test the voltage output without feeling it?
Old 05-08-2006, 04:39 PM
HotZ28's Avatar
AF Moderator Elite
You can use a spark plug with the gap opened up to .100 and insert it in each plug wire (one at a time) to test the voltage output. If it throws a good blue spark across that gap, you have a good coil.
Old 05-08-2006, 10:19 PM
Ok, thanks!
Old 07-02-2006, 09:43 PM
teedot teedot is offline
I have a 1990 pontiac 6000 with a 3.1 L. One coil pack is not firing. I replaced that coil pack, but the new one is not firing either. I pulled the ignition module and had it bench tested. It tested fine. Would someone have a suggestion where to look next?
Old 07-03-2006, 04:43 AM
HotZ28's Avatar
AF Moderator Elite
Welcome to AF!! I will leave this post in the "Buick" forums, since the Pontiac is similar, however you might want to consider posting in the Pontiac Forums.
Your problem sounds a lot like the Regal post below:
regal 1-4 coil problem
