Go Back   Automotive Forums Car Chat > Saab > 900
Old 04-28-2006, 01:40 PM
triptrop198 triptrop198 is offline
Question convertible top doesn't work
1 have a 1995 900.when attempting to put the roof down the rear window starts folding up and stops 1/2 way,then will not go up or down.you can manually move the rear window back to the closed position,but it doesn't go easily...any idea's??? thanks....
Old 05-15-2006, 01:40 AM
adept-I adept-I is offline
Re: convertible top doesn't work
Check your hydraulic fluid tank for the top to make sue that there is enough fluid in it to actuate the top. You should also look around the passenger side rear wheel for "puddles" which could indicate a leaking fluid reservior, hose, or 5th. bow piston.
Old 05-15-2006, 12:29 PM
Thumbs up Re: convertible top doesn't work
Originally Posted by adept-I
Check your hydraulic fluid tank for the top to make sue that there is enough fluid in it to actuate the top. You should also look around the passenger side rear wheel for "puddles" which could indicate a leaking fluid resevoir, hose, or 5th. bow piston.
thank's for the info!!!!!!!!!!!!!!!
