Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 04-28-2006, 01:51 AM
fanworks fanworks is offline
Determining Axle Ratio?
Okay, I just bought myself a 1992 W-250 Club Cab 5.9L 4x4 with the 4 spd auto. I'm trying to determine my axle ratios as I'm not certain what it has. All I know is the rear axle is a Dana. How can I find out what my Gear Ratio is? Will this gear ratio be the same for the front axle as well?
Old 04-28-2006, 03:44 AM
imtheoneandonlyD's Avatar
imtheoneandonlyD imtheoneandonlyD is offline
Send a message via AIM to imtheoneandonlyD
Re: Determining Axle Ratio?
Is there a sticker in the glove box? or the driver door jam?
Both axles will be the same, if they arent....well then i would recommend you dont shift into four wheel drive until they are.
Pictures of the Truck
Old 04-28-2006, 04:48 AM
There isn't any information on it except what's available in the owners manual. I figured they'd probably be the same, but I've never owned a 4x4 before so it was kind of a dumb question, but figured I might as well get it out there.
Old 04-28-2006, 07:05 AM
jrsick jrsick is offline
you can take your vin to the dodge service dept and ask them to look it up, or, go to dodge.com, contact us, and give them your vin and ask for a build sheet. Whichever you choose, ask for the whole build sheet as you may have options you don't know about.
Old 04-28-2006, 10:43 AM
edbrycem edbrycem is offline
mine is under the hood and it explains the size kind and ratio (if its still there and didn't wear off) otherwise its punched into the ring or pinion i dont remember.
Old 04-28-2006, 12:51 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
To get the approximate ratio, tape a string to the driveshaft, then move the vehicle slowly until you have one revolution of the tires. See how many times the string has wrapped around the driveshaft.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
The Following User Says Thank You to fredjacksonsan For This Useful Post:
Chris Stewart (10-15-2013)
Old 04-28-2006, 01:13 PM
troy1 troy1 is offline
AF -Advisor
^^ smart man smart man
Old 04-29-2006, 07:53 PM
HEMIDAZE's Avatar
HEMIDAZE HEMIDAZE is offline
Sometimes there is a tag on one of the rear end inspection cover bolts. My 3.92 has a tag that is stamped 3.9.
Old 04-30-2006, 09:26 AM
sneakybert sneakybert is offline
If all else fails remove the inspection cover on one of the diffs . The ratio is usually stamped into the crown gear . Another way is to count the teeth on the crown gear and divide that number by the number of teeth on the pinion gear .
Old 05-01-2006, 07:00 AM
That may be the best way to go about it -- you get your differential service done at the same time as definitively getting the ratios.
Old 05-04-2006, 11:53 PM
Well one inaccurate build sheet and a visit to a retired mechanic who knew where the axle info was stamped on them (Had to clean it off, crusty mess was hiding it) the truck has the following
Front Axle - Dana 44
Rear Axle - Dana 60
Gears - 4.10
Old 10-14-2013, 08:58 PM
wallyjohn wallyjohn is offline
I was looking to buy a 2014 ram pickup. I have choices on a 3:55 or a 3:95. Don't do a lot of pulling but it's one of those things when your doing it you don't want to close any doors. How much worse on gas will the 3:95 be?
Old 10-15-2013, 02:07 AM
About 10%.
