Old 04-28-2006, 01:31 AM
JunkTitleGolf's Avatar
JunkTitleGolf JunkTitleGolf is offline
New Amp Coming In...need some subs though.
Ok within the next 2-3 days my amp is supposed to be coming in. It's a Power Acoustik TS1920-2. So hopefully this time I did go up in quality...I went from a pioneer 520t to this...upgrade right? Anyways, I need 2 12 inch subs...I am supposed to be getting 300 dollars from my parents...any suggestions? I think the amp runs at the highest wattage when in the 2 channel mode at 2 ohms. So any suggestions for subs that run at 2 ohms or what would be a good combination so that I can run 2 subs bridged at 4 ohm. I am sorry if this seems more like ramblings rather than anything it's late and I am excited about the amp coming in.
Old 04-28-2006, 09:05 PM
colby67 colby67 is offline
Re: New Amp Coming In...need some subs though.
that power acoustic amp is for show doesnt put out that much unless hooked up to some power acoustic i saw go with some punch p2's they are good all round speakers i just installed 4 in a cuttlass and oput a 8" in a corvette if you get some power acoustic subs go with mofo's they are top of the line for them
Old 04-28-2006, 10:12 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Assasin 12's... best deal right now.
PA is.... okish
Old 04-29-2006, 11:00 AM
well with that amp best performance is with those subs
Old 05-01-2006, 01:17 AM
balls_to_the_wall's Avatar
balls_to_the_wall balls_to_the_wall is offline
A set of the following subs would be great:
Assassain 12's
IA 187's
RE RE 12's
I'm not sure of the coil configs of the IA or the AA, but you will want Dual 4ohm.
Old 05-01-2006, 01:57 PM
bjboertje's Avatar
bjboertje bjboertje is offline
the AA is single 4 ohm
the IA is dual 2 ohm
so either would work great, i recommend the AA.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 05-01-2006, 02:09 PM
Dual 4 ohm...what are some good subs that are in that configuration...also if I was to run it bridge how would I will the subs so that they both are powered...what should I look for. Also do I really need to go to 4 gauge wire to use this amp or will 8 gauge work?
