Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 04-27-2006, 11:50 PM
fiberglasscivic's Avatar
fiberglasscivic fiberglasscivic is offline
Send a message via AIM to fiberglasscivic Send a message via Yahoo to fiberglasscivic
Overheating
I've got a 93 Civic LX with the stock D15B7. I've recently been noticing that if the engine runs for 15 mins or so it starts, to overheat. It's only noticeable when the car is at lower speeds (45 and below). When I get on the interstate and travel at higher speeds, the engine cools off and my temp stays right around normal but as soon as I slow down or stop it starts to go up again. I though that maybe it was due to low fluids or a bad thermostat. I changed the thermostat and filled up the coolant. Same problem still. I've checked the fuse for the radiator fan and it's good to go. The fan kicks on. I checked for a leak and I haven't noticed any fluid leaking from the radiator or hoses. I have noticed that there seems to be an oil leak around the crank seal on the side where the timing belt is. I go through oil kind of quick but I'm not burning it. When I top off my oil it doesn't overheat as much (temp is still well above normal but not as bad). When I start cold without my radiator cap on you can see the fluid move while the engine is running. Revving around 3 g's from idle will cause the fluid level to jump up and almost overflow. If I missed anything, I'll try to answer as quickly as possible. I'm on here almost 24 hrs a day. Thanks for taking the time to help.
AF COMMUNITY GUIDELINES
Old 04-28-2006, 06:28 AM
GEESERTEG's Avatar
GEESERTEG GEESERTEG is offline
Re: Overheating
I think you have a fan problem. Setting in the driveway make sure the fan comes on when it starts to overheat. Just for a backup you can use the A/C... YES the A/C..lol Hondas have a secondary cooling fan for the engine when you turn it on. Fan probs are usually an issue with the relays under in the enigine bay. Also make sure to check all your fuses too.
EDIT!!! --bahhh -- I need read better. Ok hmm... I take it you bled the system good and all? Has there been any smoke when you start the car or during warm up?
http://www.HondaFactor.com ---- Honda/Acura Enthusiast Community
07 Habanero Red Civ Si -- baby's new baby.
94 Honda CivicEX -- 200,000mi ---SOLD
98 Acura Integra GSR --SSBP-- Tein H-techs/Tokico Blues/AEM SRI/More SOON
02 Fud Expedition 5.4 EB
Old 04-28-2006, 11:53 AM
Re: Overheating
No smoke or anything unusual, just the overheating like I described.
Old 04-28-2006, 12:41 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Overheating
head gasket, water pump, air bubble in system. I would try to bleed the system (radiator cap off, let it warm at idle, and then rev it a little). If it still does it, I'd do a compression test to check if the HG is bad. If that's fine I'd say it's likely to be your water pump (just a guess though).
Old 04-28-2006, 04:55 PM
Tofuboy's Avatar
Tofuboy Tofuboy is offline
Re: Overheating
When was the last time you change your coolant?
What is your mixture ratio?
Power is nothing without control
The fastest driver is the one with skills
95 Civic EX
83 Toyota Starlet
07 Ducati Monster S4RS
Old 04-28-2006, 11:08 PM
Re: Overheating
It has less than 500 miles on it since I changed the thermostat and coolant. The mixture is 50-50.
Old 04-30-2006, 03:10 AM
Tofuboy's Avatar
Re: Overheating
Sounds like the fluid is not moving fast enough to cool down the engine when it's just idling after it's been driven. I am guessing there might be a restriction in the radiator (some rows of the fins are clog?) orr the water pump is not doing it's job properly, when did you last change the water pump?
95 Civic EX
83 Toyota Starlet
Old 04-30-2006, 01:54 PM
Re: Overheating
I've owned the car for about 9 months and I haven't changed it. There's no telling when it was last changed but that was next on my list. While I'm there I'm going to fix the seal on the crank to keep the oil from leaking. Hopefully that will fix it.
Old 05-03-2006, 02:48 AM
93civicsiracer 93civicsiracer is offline
Re: Overheating
have u checked the relay switch to the fan. that was my problem when i had my d16z6
Old 05-03-2006, 08:39 AM
Re: Overheating
Originally Posted by fiberglasscivic
...I've checked the fuse for the radiator fan and it's good to go. The fan kicks on. ...
Been there, done that.
Old 05-05-2006, 10:34 AM
hxgaser hxgaser is offline
Re: Overheating
I say it probably is either your water pump or the radiator. If the fluid inside your radiator is and was nice an clean prior to your refilling, then probably it is your water pump. How many miles does the car have on? It might be a good time for water pump/timing belt job.
One thing that is interesting is that you have fluid circulating when the car is cold. Technically coolant should not recirculate when the car is cold and the thermostat is closed. Interesting...
Old 05-05-2006, 05:49 PM
Re: Overheating
I've got about 180,000. It's definatly time to change the belt.
Old 05-09-2006, 12:23 AM
Tofuboy's Avatar
Re: Overheating
Please let us know what happens after you replace the crank seal, water pump and timing belt, so we might able to use this info for future reference.
95 Civic EX
83 Toyota Starlet
Old 05-09-2006, 06:19 AM
Re: Overheating
It's gonna be a week or two, I don't have the money for all of it yet. Does anyone know a good write up for replacing the crank seal? Also, I decided to go do some prowling and the other day. My car has been sitting for almost a month and a half. I cranked it up and let it run until it got to normal temp. When it didi I took off the radiator cap and my coolant was low by about two quarts. I know when I parked it that it was full. I decided I would look for a leak. I didn't notice any cracked hoses or any cracks in the radiator. I'm going to replace the hoses while I'm at it. The only thing I did notice was a spot on the tranny side of the valve cover where it looks like it's leaking oil. I hadn't noticed it before. It's really small. I'll definatly let you guys know when I replace everything though.
Old 06-05-2006, 04:37 PM
Re: Overheating
UPDATE: I haven't had any money to do anything yet but the car is on blocks and I'm having trouble breaking the bolt on the crank pulley. It's still gonna be a few weeks untill I get it finished. Any help on the crank pulley would be appriciated. I've already broken a socket trying. I'm about ready to try an impact wrench.
