'95 Transmission Neutral Safety Switch
Recently my '95 Windstar (151,000 miles) has been either defaulting to 2nd gear or shifting back and forth between 2nd & 3rd very erratically. Now the OD light on the shifter is flashing so I'm sure there is a code to be pulled off for this problem. A couple postings suggest a "neutral safety switch" could be the culprit. My understanding is that a bad switch will prevent information to be sent to the PCM and the tranny won't know when to shift. Can anyone shed more "technical" insight and where the switch is located?
Thanks, Paul Scanzillo |
Re: '95 Transmission Neutral Safety Switch
It's also called a "Transmission Range Switch" or TRS:
![]() This thread has some tips for checking it: http://www.automotiveforums.com/vbul...d.php?t=554854 |
Thanks much for the diagram. I went ahead and installed a new TRS and all seems to be well. I disconnected the battery to allow the system to reset and the OD light is off with the tranny shifting as it should.
Praise God! Paul Scanzillo |
