Old 04-27-2006, 07:56 PM
hot_sd hot_sd is offline
Platinum Spark Plugs
Time to change the spark plugs again! Was wondering about the pros and cons (if any) about using platimum vs normal plugs (apart from the price). Wonder if anyone can comment on them. Also would be interested to hear if anyone has had any improvement in performance using the Bosch +2 and +4 platinum plugs - are they really worth the extra money.
Old 04-27-2006, 10:39 PM
spy1309 spy1309 is offline
Re: Platinum Spark Plugs
Yes you can see improvement with +4 in turbocharged, superchared and high compression engines.
+2 and regular platinums in regular engines the only improvement is longer service or replacement interval life.
Old 04-28-2006, 12:39 AM
stamar stamar is offline
no
I counter the fact that they not only are worse, they will have a shorter life span.
your plugs will stop being effecient when they are dirty. You cannot take out and clean a platinum plug you will ruin it and the metal is too brittle.
resistance in the plug is higher, platinum conducts worse than copper. its a material used for heat resistance.
only if your car came from the factory with platinum plugs should you use them. these cars have a combustion chamber made to realisticly give the plug a chance at life advertised.
I have a metro. Ive driven with them both back to back, recently.
use ngk or bosch regular copper plugs you will get better performance and gas mileage.
Old 04-28-2006, 04:25 PM
Thanks for the feedback - I guess I'll just stick to the regular plugs. Yes, good point about the conductivity - just checked the electrical conductance table and did not realize what a poor electrical conductor platinum is compared to copper. Of course copper is one of the best conductors of electricity.
Old 04-28-2006, 04:56 PM
geozukigti geozukigti is offline
A platinum plug will perform the same as a regular plug with a slightly larger gap. For example, a standard plug with a .031-.035 gap should be set to .039-.044 with a platinum plug. It will take more voltage for the spark to clear the gap, therefore, creating a spark of equalivent temperature. And the platinums will last a LOT longer, and maintain a sharp edge on the electrode much longer than a standard plug. Performance-wise, no, there is no advantage to a platinum plug. If you want a flat out performance boosting plug, get Iridium. But, they don't last very long until the electrode starts to break down. If you want a better spark, upgrade your coil and wires. A nice Blaster SS coil is only about $40, and you get a 48,000 volt spark. It takes about 20 minutes to install it into your car, and it's a big improvement. So if you're gonna piss money away, piss it away at the start of the spark, not the end. You'll get way better results.
Old 04-28-2006, 10:46 PM
DOCTORBILL's Avatar
DOCTORBILL DOCTORBILL is offline
Geo Metro Lover
In every automobile that I've bought (all used - won't piss money away on a new car),
I found a consistant 2-3 mpg increase by putting Bosch Platinum Plugs in them.
Those plugs have a porcelain inner plug with a tiny hole the spark goes into.
I have had parts clerks tell me some cars do better with them and others that they
actually do no good in. Personally, I think that is all rubbish.
All of mine did better.
VW Rabbit, Honda Civic, Chevy Suburban, two Jeep Cherokees, now my Geo 3 cylinder.
Be a scientist, my man - do the EXPERIMENT!
Only costs a few bucks more to try them.
Be sure to determine your current mpg first, so you'll know if there is an improvement!
If not satisfied, put the old types back!
That is how we find answers!
DoctorBill
PS - "Conductivity" variability is of little concern at 15,000 volts. And no spark plug is made
of solid Platinum! Platinum plated. Platinum currently goes for about $1,150 per ounce!
http://www.kitco.com/market/
Old 04-28-2006, 11:48 PM
Well I'm an engineer (I guess that's close enough to being a scientist) and am always doing experiments (developing new products) although generally always for other people. Yes, lots of different opinions and I guess the only way to find out is to try it. Not sure why there is such a difference of opinions on the subject - pretty much the same if you look on the web - some people claim better performance and others worse performance. And yes, I guess the amount of current being conducted at that voltage is pretty small anyway.
Old 04-28-2006, 11:53 PM
This performance improvement due to the coil - can you quantify that - do you mean better acceleration, power or economy or what exactly. Never heard of this product. Also is it a direct replacement for the existing coils.
Old 04-29-2006, 02:26 AM
look
your car cost at least 10k new.
ok. If platinum plugs gave you an increase in mpg, like 1 mpg. forget that, 1/50 mpg.
1 horsepower...... 1/10 of one horsepower
suzuki would have put them in the car to start with. they would have sprung for the um.... $1.50 more. They might even get a deal on them. Being an auto manufacturer and all. They might even have a good idea what sort of difference it would make in performance.
platinum is a heat resistant metal. It is used in such as mufflers. a platinum plug is a copper platinum alloy.
In theory they will "LAST' 100k miles.
ANYONE
ANYONE who thinks that their plugs go bad by the spark melting the gap....
doesnt know anything about cars. Im sorry. Hopefully I can help you learn.
Your plugs go bad when they are dirty. when carbon has built up on them resisting the spark.
platinum plugs will get dirty just as fast. only you cant clean them with a brush.
a softer copper plug, can be regapped and the dirt filed off and put right in.
So it has a LONGER possible life, although really its just the same because youre likely to just replace it.
I have tested it. with 3 different kinds of plugs, recently. The copper, being a better conducter of electricity has an advantage in performance right away, when new.
some newer cars, newer than your metro, use such powerful spark that the DISADVANTAGE, the resistance of platinum is almost nothing. The chamber the plug goes into has a special grate to keep blow back gasses from forming deposits on the spark plug. These cars keep their spark plugs cleaner longer. They come from the factory with platinum spark plugs installed. these cars would do well to have platinum spark plugs, such as a new corvette or integra or some such. these cars use capacitorys on each plug wire.
Does your metro do this? No.
your new platinum plugs were clean. Buy three new ngk plugs and you will notice a difference. right away like I just did when i took out the autolite platinums and put in ngk plugs. the new platinums were much worse than the bosch standards that were in there before and had about 30k miles on them.
Old 04-29-2006, 10:52 AM
Mike_Van Mike_Van is offline
I asked my imported car parts guy about Bosch platinum plugs and he told me that NKG would be a better choice for my 3 cyl 1.0 '96
Old 04-29-2006, 04:53 PM
yes ngk plugs are exactly what you should use. Seeing as not only are they more expensive, suzuki sprang for them in the final assembly of your car. If bosch were better or the same they would have used those
go ahead and buy a set of 3 of each and watch. I mean this is the perfect car to experiment by feel, the small difference of spark will show right from a dead stop.
Youll even see by mixing, put a bosch platinum in one cylinder and watch the vibration.
all testing and performance and driveability were done by the manf with ngk plugs in there. So even if iridium or titanium or dilithium positronic plugs were put in somehow magically creating more spark ( impossible) the fuel and timing is not tuned for it, it could only create predetonation at best.
The xfi uses a stronger coil and advanced timing. And ngk plugs. It reality Ive seen the xfi get worse gas mileage than the standard because it is a trick that probably only runs right when its new.
Old 04-30-2006, 02:22 AM
i need to add to the spark plug concept Im trying to relate ok, so I dont confuse anyone.
No spark plug makes more spark. none. what you are trying to do is perfect the TIMING of the spark. ok well iridium does ok by chemical reaction but nm.
When it gets dirty, the TIMING of the spark is changed. The plugs are no longer firing in perfect TIMING to eachother and the fuel bursts.
By changing spark plug brands, you are slighly changing the TIMING of the spark.
a platinum plug could not make the TIMING of the spark any better, it could only make it worse or at best do nothing.
in theory as some components of your vehicle age the gap of your spark plugs changing could help performance as opposed to what was stock. So in theory changing from the stock ngk plugs to something else could help a out of tune vehicle.
Im just trying to paint a possible scenario for people possibly giving themselves bad data. because its actually a bass ackwards way to do things. you can put the wrong plugs in and change the distributor timing even. reprogram the ecu for different fuel bursts....
but if any plug other than the stock plug makes your car run better, then your car is screwed up. It could happen dont get me wrong. But it tells you something else also.
Old 05-02-2006, 06:09 PM
theragtopguy theragtopguy is offline
When I first got my Metro it was not idling smoothly. I pulled the plugs and they happened to be the Platinum variety, Bosch.
I replaced them with NGK and everything smoothed right out.
And it is true that some vehicles just do not like those plugs. If I were to put them in my 93 Olds 3.4 DOHC engine it would run crappier, I've seen it before. They don't like the 'waste spark' ignition system used on that type of engine.
I figure that since the Japs that built the Metro put NGK's in it, they must know what they are doing since they designed it.
Old 05-03-2006, 12:36 AM
More interesting opinions. Anyway I have decided to stick with the NGKs this time. Interestingly the FSM from GM does specifically recommend either Denso or NGK plugs. Since they do not specifically recommend anything else as far as a brand is concerned maybe there is a reason for this as some are suggesting.
Old 05-03-2006, 12:37 AM
As an alternative is it possible the plugs were damaged rather than this being due to them being platinums.
