Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 04-27-2006, 06:36 PM
marksw13 marksw13 is offline
replace head light bulb
I need to replace the head light
Old 04-28-2006, 02:49 AM
InnerDragon103's Avatar
InnerDragon103 InnerDragon103 is offline
Send a message via AIM to InnerDragon103
Re: replace head light bulb
ok thats a little hard for us to answer if you dont tell us what year altima you have... on top of that, that information is easily found in your vehicle's manual, in your passenger glove compartment
actually i'd like to ask a question regarding my 94 altima's driver side headlight... i changed the two of them a few months ago b/c the one on the driver's side blew... then about two months later, the same bulb blew... is this just coincidence or is there an electrical problem im not picking up on?
~1994 Altima GXE 5 speed~
Current mods:
Short Ram Intake
Tint
8500K headlights
New sound system, 2 12" subs (600W)
Old 04-30-2006, 05:39 AM
FixUrNissan's Avatar
FixUrNissan FixUrNissan is offline
Uh .. The right one or the left one? What Year Car . Little more info could help us to possibly help you
Old 04-30-2006, 07:41 AM
Eclipsebella86's Avatar
Eclipsebella86 Eclipsebella86 is offline
Im having the same problem, my mother has an 03 altima and even though Im a girl, my tiny fingers aint geting to those bulbs
please help guys
Cardomain: http://www.cardomain.com/ride/2249920
Dark Butterfly:
Vibrant Strut Bar
Full Eclipse Sound System (2 12"s, 4 door speakers, 2channel amp and 4 channel amp and deck)
pink plasma glow neons under the dash (cuz Im a girl)
Custom sub enclosure (http://www.cardomain.com/member_page...20_43_full.jpg)
pink trim
Blitz Kit
pink grill mesh
10% tinted windows
Old 10-10-2006, 10:36 AM
MmeT MmeT is offline
my driver's side headlight has been going out every few months too. (97 altima). Don't know how it is for an 03, but for changing the same headlight in a 97, easiest/quickest thing to do is take the battery out. 4" of space to almost 12". as for the passenger side, supposedly you can take the coolant reserve tank out, but thus far i've never had to. http://autorepair.about.com/library/faqs/bl258h.htm
on a revised side note, it's really easy to replace the passenger headlight once the coolant tank is removed. might need a bit of tough love to remove it, but once it comes out, easy sailing from there on out.
Old 10-10-2006, 05:12 PM
Changing a Headlight bulb for 02 ALtimas and up , are a little tricky. There is a ground plate that has to be on the back of the bulb. If one is not present then it may be subjected to a recall , call Headlight Ground plate recall. The recall Consists of inspecting your head lamp assembly's and installing the ground plates. If nay bulbs are out Nissan will replace them at no charge.
In any case to replace the bulbs for 02 and up there is a Big screw cap seal that has to be removed then you have a spring clip holding down the bulb , then you have to take the bulb out with the ground plate. Transfer ground plate to new bulb , Note, it just lays against the bulb it doesn't snap or stay on it, When you put the bulb in it's a little tricky to hold the bulb and ground plate to put clip back on. If you can get that far Then all you have to do it put the big plastic cap on , witch could be a little tricky also. Gl..
Old 10-17-2006, 05:37 PM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
My 95' right side bulb is very dim, and it's been about three months since I replaced them and it is dim again. My passenger sid is just fine. Any suggestions?
As for changine the bulb, the coolant tank is easy to take off, and the battery even easier to remove. Good luck.
