Old 04-27-2006, 07:05 PM
boarder_punk's Avatar
boarder_punk boarder_punk is offline
Send a message via MSN to boarder_punk
4 Bolt Main
Does anyone know why some engines with a 4 bolt main will only have a 2 bolt cap on one end of the block?
Old 04-28-2006, 07:59 AM
CraigFL's Avatar
CraigFL CraigFL is offline
Re: 4 Bolt Main
The bearings in between the ends take the load of multiple pistons/rods(on both sides of the bearing) while the ones on the end take less load because there is only a load on one side of the bearing.
Old 04-28-2006, 04:10 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: 4 Bolt Main
I believe it also has to do with if the engine uses one piece or two pieces seals- not possative though.
Old 04-28-2006, 07:02 PM
Re: 4 Bolt Main
Alright, that makes sense guys, thanks. It just confused me when even a Keith Black top fuel hemi block (up to 8000 hp) used 6 bolt mains on a y block design yet the end was still only 2 bolt.
