Go Back   Automotive Forums Car Chat > Nissan > General Discussion
Old 04-27-2006, 04:59 PM
dnadan dnadan is offline
Black smoke, erratic behavior
This refers to an 88 Sentra with a throttle body. I have been experiencing black smoke for several weeks with erratic engine behavior including lack of power above about 1500-2000 rpm that worsens as the engine heats. I completely changed the throttle body, changed plugs and wires, swapped computers, even put in an oxygen sensor when this all began. Nothing seems to help. The engine remains full of carbon and the plugs black. I'm about to give up on it. Any ideas?
Thanks,
Dan
Old 04-28-2006, 12:28 AM
psychopathicdude's Avatar
psychopathicdude psychopathicdude is offline
Re: Black smoke, erratic behavior
Checked the fuel regulator? Excessive fuel pressure could be causing an extreme rich condition....
Old 04-30-2006, 12:11 AM
crazylost crazylost is offline
is the egr valve stuck open????????
Old 06-14-2006, 04:06 PM
marco829 marco829 is offline
Hello. i too have a nissan sentra but it's a 1987. I also experience sputtering at high rpms and it gets worse as the car warms u p. I travel 75 to 80 miles per hour to work and it really gets bad at 75. especially when i maintain an even speed at that mph. I have heard that the fuel regulator is suspect. For the throttle body they're $109.00 to $124.00 depending if their is one or two lines on it. I'm taking my car to a nissan dealership tomorrow for them to plug in and isolate the problem. I'll keep you posted.
Old 06-19-2006, 03:57 PM
Having taken my 1987 sentra into a dealership to diagnos a similar problem, the computer was kicking out a code for the isc valve (aka IAC motor). It is located on the back of the throttle body. It can be purchased aftermarket at autozone for $130.00. I'm buying mine tonight.
Old 08-16-2006, 10:15 AM
nissan_240sx nissan_240sx is offline
Also check if your catalytic converter is clogged.. its an 80's car never know whats in there LOL. but yeah check the cat
-Matt
NISMO
1992 240sx SE Fastback 5speed
