Go Back   Automotive Forums Car Chat > Toyota > General Discussion
Old 04-27-2006, 02:09 PM
jamesmetairie jamesmetairie is offline
paint it yourself=
i have an old car that cost me $1200. THE BLACK PAINT and clear TOP COAT ,ETC IS PEELING,BLISTERING.IT,S MOSTLY ABOVE THE PIN STRIPE. what,s the best method to prepare it for paint. can i use a little orbit sander?should i use wet type sand paper and run some masking tape along the pin stripe? i ain,t decided yet if i will spray the primer from cheap cans and then top coat with a brush. i had a cheapy car 40 years ago painted with a brush and it was not too bad. no, it would not win at the custom car show.but it was a clean go to work car(fishing car).anyone have any luck spraying top coat with cans??? no, i ain,t embarassed. i,m in katrinaland .
Old 04-29-2006, 07:01 AM
DFBonnett DFBonnett is offline
Re: paint it yourself=
If you go to a good parts store, some of the big box stores, even online at www.bn.com or www.amazon.com there are some good, inexpensive books on basic body work. There are more details and pictures there than someone can give you in a half a dozen lines on the net.
FWIW
YMMV
Old 05-16-2006, 06:06 PM
i painted it with cans(quick drying car paint) from walmart. i taped above the pin stripe. sanded between 2 black primer coats. then top coated 1 black coat. i did not give it any clear coat. it ain,t too bad. also i painted both bumpers.Save your money!!!!!!!!!!!!!!!!!!!!!
