Old 04-27-2006, 12:14 PM
mike1224's Avatar
mike1224 mike1224 is offline
Send a message via AIM to mike1224 Send a message via MSN to mike1224 Send a message via Yahoo to mike1224
home network (fixed)
i've got 2 computers right now, and would like to share files between the two. I thought I had everything right, but when I click on the other computer icon from the view workgroug computers it tells me i do not have priviledges. What have i messed up on?
2002 Chevy S-10 ZR2
Originally Posted by balls_to_the_wall
Some people are alive only because its illegal to kill them.
Old 04-27-2006, 12:53 PM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
Re: home network
Well of course make sure the comps are connected properly (crossover if direct conection).
Then run the stupid "Set up a home network" wizard and turn on file and priter sharing, windows will often not let you share unless you run that first.
Oh after you run that wizard make sure to go in my comp and you'll see a shared folder windows activates by default. Go in its sharing properties and unselect "allow other people to change my files" which Microsoft in its great wisdom decided to turn on as default after that wizard.
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
Old 04-27-2006, 02:05 PM
mike1224's Avatar
Re: home network
still no luck.... "Computer 1 could not be found on network"
2002 Chevy S-10 ZR2
Old 05-01-2006, 01:03 AM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Send a message via AIM to Oz
Re: home network
Are they on the same workgroup? Can you tell us what IP address each computer gets?
Originally Posted by RaeRae1
Blessed are the cracked ones for they are the ones that let in the light.
Old 05-01-2006, 05:02 AM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Re: home network
what cables are required to connect two computers? i'd like to connect two but i'd rather have a solid connection instead of a a wireless one.
Seatbelts Saved My Life
Old 05-01-2006, 09:37 AM
mike1224's Avatar
Re: home network
yes, they're on same workgroup "workgroup" -win assigned it.
ip's::: comp 1: 192.168.12
comp 2: 192.168.7
2002 Chevy S-10 ZR2
Old 05-01-2006, 06:48 PM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Re: home network
What is the rest of the IP addresses? Can you open up a command prompt (start, run, type 'cmd', press enter) then type 'ipconfig/all' and copy and paste the results for both computers?
Try pinging the other computers IP address (type 'ping [ip address]')? Does it time out or does it get a response?
Are you running any firewalls on either computer?
How exactly are they connected? Through a piece of network hardware like a switch or a router, or with a direct crossover cable?
2.2 Straight six - if you just want to connect two computers and they both have their networks cards free, get a crossover cable from your local computer store and Bobs your Uncle. If you need to share more than 2 computers, internet connections etc, get a cheap router. Netgear are pretty easy to setup out of the box.
Old 05-01-2006, 10:13 PM
mike1224's Avatar
Re: home network
they are connected through a router. firewalls are windows and bullguard
tried pinging.. it timed out.
2002 Chevy S-10 ZR2
Old 05-01-2006, 10:23 PM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Re: home network
Disable all firewalls and try again. What happens when you try to login to the router (192.168.1.1)? What does it list under 'connection status' or 'connected devices' or whatever?
Old 05-01-2006, 10:44 PM
mike1224's Avatar
Re: home network
OZ YOU DA MAN!!! thank you.... is the firewall on the router sufficient?? or so i need to adjust the windows firewall?
2002 Chevy S-10 ZR2
Old 05-02-2006, 04:41 AM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Re: home network
Try and isolate the fault to one or the other. Try this: turn the Windows Firewall on first. If everything works, it's the router firewall that's blocking. If everything stops working, Windows Firewall is the problem. You can add an exception to Windows Firewall really easily, just have a look around.
If it's the router, have a read through the users manual or online documentation about which ports you need to open, or what you need to do to enable Windows File and Print Sharing. You can probably find the setting pretty easily if you login the router and have a look around.
Glad you got it working. (I'll rename your thread).
Old 05-02-2006, 10:47 AM
mike1224's Avatar
Re: home network (fixed)
got firewall back up, so everyone else knows, goto start --> settings --> control panel --> Windows firewall. First I turned on the firewall. then went to the tab "exceptions". I clicked on Add Program, then on the bottom left corner click "change scope..." choose "my network" then OK. you should have firewall back up and be able to let the computers communicate
2002 Chevy S-10 ZR2
