Old 04-27-2006, 12:01 PM
hagglerock hagglerock is offline
1999 Grand Prix A/C
I believe my unit is just low on freon but would like to confirm. Does anyone know the correct method to jumper out the pressure switch to see if the compressor clutch will engage. My switch is a three wire unit.
Thanks in advance
Old 04-27-2006, 12:18 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 1999 Grand Prix A/C
The problem with jumping out the pressure switch is it is a low and high pressure switch. Therefore, the jumper will have to include a resistor representative of normal pressure to fool the PCM into turning on the compressor. Best thing to do is check the pressure at the low pressure port. If real low based on ambient temperature just recharge using one can of 134a. Once sufficient charge is established the compressor should start cycling without having to run the jumper.
Timeslip 08/12/06
AF Community Guidelines
Old 04-28-2006, 03:09 PM
edbrycem edbrycem is offline
make sure u r allowed to do your own a/c charging. Here in Wisconsin its illegal w/ a hefty fine if u r caught w/out a license charging your system. but in minnesota u can buy it off the shelf in walmart, so states vary. my 99 leaked over the winter, iguess the 134 is thinner then the older freon so when it gets cold it often times leakes out of the seals. FYI, thats all, i'm bored
Old 04-28-2006, 03:15 PM
BNaylor's Avatar
It is not illegal in Texas to purchase R134a and do your own recharge. He lives in Kentucky. Yeah those eco rules in green states are a trip.
Timeslip 08/12/06
Old 04-28-2006, 03:51 PM
SNKPWR SNKPWR is offline
you can purchase r134a and recharge your own system in kentucky...
-2002 Grand Prix GT Black
Old 05-19-2006, 09:16 AM
tjaygrid tjaygrid is offline
I bought a R-134a recharge and cannot get the quick connect to fit either port on my 1999 Pont. Grand Prix. I know you are supposed to perform on the lower port, but is too big. The other port is too small.
Old 05-19-2006, 04:17 PM
BNaylor's Avatar
The low pressure port is located at the firewall so try there. There is a blue cap on it. Some of those recharge kits and quick connect couplers are cheap.
Timeslip 08/12/06
