Go Back   Automotive Forums Car Chat > Mercedes-Benz > E-Class
Old 04-27-2006, 05:57 AM
RMT6668 RMT6668 is offline
BAS/ESP & ABS fault indicator on
Hi
My E240 2001 BAS/ESP & ABS came on yesterday whilst I was driving. The 2 indicator came on at the same time. But each time I turn off the engine & restart the 2 fault indicators dont come on till I depress the brake pedal.
Checking my service record, on 15/07/05, the Front Brake Pad, Brake Disc and Brake Fluid had been replaced.
Can some pls help diagnose this fault? Prviously I had these kind of fault indicator lights up when I unplug & plug back the battery under the back passenger seats.
Kind Regards,
Old 04-30-2006, 11:22 AM
99avenger2.5 99avenger2.5 is offline
Re: BAS/ESP & ABS fault indicator on
without any codes it is hard to diagnose, but the most comon problem is the stop lamp switch. it is located behind the brake pedal. check to see if your brake lights are working properly, however they may still work fine if the swich is faulty. it is easy to change. you just have to remove the panel below the dash and you will see the switch. their are two plugs going to it. the switch comes out by turnig it about 1/8 rotation then pulling it out. when you install the new one you have to install it with the plunger all the way out.
