Old 04-26-2006, 08:16 PM
Hardknox918 Hardknox918 is offline
Tranny Slams into gear when cold
Hi. Any hints for an 89' Honda Civic DX automatic transmission that slams into gear when cold? It happens in both forward and reverse, and then lessens in impact when the weather warms up. I was thinking about a power flush, but if anyone else has any suggestions I am all ears. Thanks
Old 04-26-2006, 08:19 PM
2poor2tune's Avatar
2poor2tune 2poor2tune is offline
Send a message via AIM to 2poor2tune
Re: Tranny Slams into gear when cold
hers a hint auto to manual swap. j/k i dm not sure so i will let the automatic guys handle it. layta
Old 04-27-2006, 10:17 PM
livinincalifornia livinincalifornia is offline
Send a message via AIM to livinincalifornia
I had a problem with an auto that has high cold idle, whenever the engine is idling high there is supposed to be something that compensates and doesn't kick in the gear as if you're pressing the gas, does it jump if you're in park and shift to drive? It has something to do with the high idle I believe but I'm not sure what.
Old 04-27-2006, 10:34 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Would make sense...The car idles high when cold, and its not supposed to go into gear at those speeds...
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 04-28-2006, 08:02 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Get a tranny fluid flush/change. See if that helps.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 04-28-2006, 12:50 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Ditto.
Usually it's one of 3 things that all auto tranny problems are related to.
1. old fluid/wrong fluid
2. torque converter bad
3. shifter cables need adjusting
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 04-28-2006, 02:29 PM
FrodoGT's Avatar
Torque conver is a definate possibility..Never even thought of it, too used to manuals. The stall rpm could be messed up on it, likely from the fluid in it, that would cause it to suddenly jerk, seemingly into gear. I second the fluid flush.
Current project:
Rio Red 91 hatch.
