Old 04-26-2006, 07:54 PM
Moze's Avatar
Moze Moze is offline
$500 - What to spend it on...
Well, in a nutshell, my truck is listed in my sig.
'03 Silverado 4x4 extended cab, Nelson Tuned, electric fans, True Flow intake and cat-back dal exhaust that was on there when I bought it (can't find a name brand) with 3" tips.
So I have about $500 I'm looking to spend and am looking for ideas. Would I like it to have more 'umph'? Of course. I don't think I can swing a cam though, it would be about $900 installed. So I'm thinking headers? Stall converter? Different exhaust? Can you upgrade just injectors? I need a shift kit and was thinking of doing that and a servo...
Throw me your ideas, I'm open to 'em!
2003 SILVERADO Z71 ECSB 5.3L - NELSON TUNED - YANK 2600 CONVERTER - DOUG THORLEY TRI-Y HEADERS - SPIN TECH MUFFLER - 224/224 .563/.563 112LSA CAM - TRUE FLOW AIR INTAKE SYSTEM - PORTED THROTTLE BODY - THROTTLE BODY BYPASS - LS1 ELECTRIC FANS - NELSON FAN HARNESS - 160° T-STAT - WALBRO FUEL PUMP - AMSOIL SYNTHETIC OIL - WWW.LS1TRUCK.COM
Old 04-27-2006, 08:57 AM
Slowprocess's Avatar
Slowprocess Slowprocess is offline
Send a message via Yahoo to Slowprocess
Re: $500 - What to spend it on...
I'd go for the pacesetter long tubes. They really do help out on the performance aspect, and will compliment your current intake/exhaust setup. A converter would simply be a 1/4 mod if you want to go that route. Plus, for a good converter with a stock tow rating will most likely be over that $500 mark. To answer your question, yes you can upgrade the injectors, but you'll have to get Allen to tune for it. You can pick up a set of 8.1L injectors pretty cheap. They are a nice upgrade from the stock 4.8, 5.3, and 6.0L injectors. A shift kit and servo is always a good mod, and you can have Allen drop alittle more TM.
Daily Driver- 00 Camaro SS A4 1/4- 12.30@118mph 2.14-60ft on street tires
Weekend Warrior-99 Silverado "Dirty" 1/4-11.63@118mph 1.8-60ft
