Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-26-2006, 04:52 PM
TeamRedLine23's Avatar
TeamRedLine23 TeamRedLine23 is offline
Send a message via AIM to TeamRedLine23
fuel pumps?
I searched but I didnt find the answer I was looking for. Will a 1g fuel pump fit in a 2g? thanks
1997 Eclipse GS-T
Performance modification:-evo3 16g-K&N Intake-HKS SSQV b.o.v vented-2.5'' Dejon tool blow thru upper and lower-Dejon large smic-GM MAF-MAF Translator-HKS 3" Carbon Fiber Titanium TBE-stock fuel rail-Walbro 190 fuel pump-PE 650cc injectors-Accel Thundersport wires-NGK series 7 spark plugs-1g intake mani/head-
Interior Modification:-Autometer Boost Gauge
http://www.cardomain.com/id/xTeamRedLine23x
Old 04-26-2006, 05:17 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: fuel pumps?
well I'm not 100% sure, but vendors do have them listed for sale as 1g or 2g, so I would guess no.
now - 2000 civic
soon - 2002 is300
Old 04-26-2006, 05:22 PM
Re: fuel pumps?
thanks it was a lot of help
1997 Eclipse GS-T
Old 04-26-2006, 10:51 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: fuel pumps?
Why on earth would you want to put that pussy ass 1g fuel pump into the 2g? The 2g supports 10lb/min more airflow.
DSM geek
Old 04-26-2006, 10:57 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: fuel pumps?
so if it supports 10lbs/min more, how much is that total?
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 04-28-2006, 11:45 PM
Re: fuel pumps?
I just asked because this guy at work thinks he knows so much about the 2g's. So I just wanted to know if it did or not.
1997 Eclipse GS-T
Old 04-29-2006, 01:29 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: fuel pumps?
Chances are he doesn't. People that say they know alot about DSM's turn out to know very little.
95 Talon TSI AWD
97 Eclipse GST
Old 04-29-2006, 01:36 AM
Re: fuel pumps?
We'll, using the factory enrichment values over 2.1g/rev, assuming 43.5psi on the stock 2g FPR and a re-wire job done. You're looking at a max of 26.5 GPH of fuel flow on the 1g fuel pump, that caculates out to 26lb/min @ 15psi using thoes values as an example. the 2g fuel pump will push 34GPH and a max of 35lb/min at 15psi, same values.
Of course if you have an safc2 or other air/fuel controling device you can lean the massive 55% enrichment over 4500rpm's out to what ever you want. For example. If you tuned the 1g pump to 11:1 (same past values) you would net a max of 31lb/min airflow & 40lb/min airflow on the 2g pump.
DSM geek
Old 04-29-2006, 08:34 PM
steviek's Avatar
steviek steviek is offline
Re: fuel pumps?
What is the best way to get at our fuel pump\
under the back seat?
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 04-29-2006, 08:36 PM
Re: fuel pumps?
www.vfaq.com has a good How-to..
DSM geek
Old 04-29-2006, 08:58 PM
blk_srt's Avatar
Re: fuel pumps?
so if the stock pump flows up to 40lbs/min does that mean that with an injector upgrade it will flow enough for a 16g?
Mods:
Old 04-30-2006, 12:01 AM
Re: fuel pumps?
No, not really. You won't be able to max the turbo out. But you could use it, I wouldn't recomend it though.
DSM geek
Old 05-07-2006, 11:32 AM
Re: fuel pumps?
I know that the awd 2g and the fwd 2g have different set ups but will a awd pump fit on a fwd car? I have been searching this question for about 45 minutes and to tell you the truth Im tired of reading. thnaks
1997 Eclipse GS-T
Old 05-07-2006, 12:11 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: fuel pumps?
I don't think so because for some reason the awd nd fwd's have completely different fp set-ups. Did you buy the wrong one or something?
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 05-07-2006, 12:16 PM
Re: fuel pumps?
They have diffrent harnes's. http://www.automotivearticles.com/12...nversion.shtml
