Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 04-26-2006, 02:23 PM
delucaj delucaj is offline
Question Stiff Barn Door Hinges
The rear barn doors on my '99 Suburban have become very stiff to open. I have tried lubricating the hinges with white lithium grease, but the problem still persists. Is there a special way to lubricate these hinges?
Old 05-06-2006, 08:53 PM
Boomyal Boomyal is offline
Re: Stiff Barn Door Hinges
White lithium grease has no penetrating qualities. Get a good penetrant and keep working the doors back and forth. Once they loosen up get a heavier penetrating lube like Tri-flow or equivalent. Then lube them periodically.
Old 05-07-2006, 05:24 AM
Blue Bowtie's Avatar
Registered Offender
Get them freed up as "Boom" stated, then use SAE20/ISO64 mineral oil periodically to lubricate them. Spray "lubricants" are not the recommended product for hinges and latches. Read your factory service manual.
Old 05-24-2006, 10:01 PM
J Rainey J Rainey is offline
I don't remember the exact set up on the hinges, but if you can remove the doors and grease the hinges that will work great.
Jason
Jason R.
