Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 04-26-2006, 03:22 PM
andic0ntr0ly0u andic0ntr0ly0u is offline
Unhappy please help! with timing belts
can someone please help me im trying to replace the water pump and have everything stripped down but the timing belts im not to sure about can someone tell me how to take them apart and put them together?
Old 04-27-2006, 06:36 PM
CobraCDN's Avatar
CobraCDN CobraCDN is offline
Send a message via Yahoo to CobraCDN
Re: please help! with timing belts
Assuming your working on the 3.5L engine `94 to 97 (I think this is the only one that has a belt pre 1997? after that I don't know)... Make sure the engine is @ #1 TDC. You'll see the marks on the block for both Cams (Upper Left and Right) and the Crank (Bottom centre) Align all the marks on the cams and crank to these marks before removing the tensioner!!!!!!! Then don't turn anything. Serious damage can occur if this is not followed!
Facing the engine on the lower left and slightly above the crank you will see the tensioner. It's pushing on the tensioner pulley which tensions the timeing belt. Below it is the tensioner. You need to unbolt it. That will relax your belt enough to get it off. To reset the tensioner before re-installing you need to clamp it in a big C Clamp or perferably a Vice. It takes quite a bit to compress it. When I did mine it actually bent the allen wrench lol.
Once compressed you can insert a small allen wrench into the hole to lock it. You can rebolt it on the engine.. make sure your allen wrench is sticking out the front or you will not be able to remove it when the time comes.
Install the water pump
Install your new belt starting from the Crank and work counter clockwise Once you have it on.. and double check your marks... pull the allen key out.
Old 04-27-2006, 07:14 PM
AWP9521 AWP9521 is offline
I strongly suggest getting a Haynes or Chiltons manual for the car, while CobraCDN's description is pretty accurate, the manuals go into good detail and illustrate what you are looking for with some nice clear photos of the job, well worth the investment to have with you while doing the job.
Originally Posted by AWP9521 - 02/16/2005
Sure sex is a thrill too, but your modified car will never tell you
"Sorry honey, I just don't feel like it tonight" it will always be in
the garage silently waiting for you to hop in so it can thrill you
some more, that is unless you break it. At least they're easier
to repair and get the thrill back than a pissed off girlfriend.
Old 04-27-2006, 09:19 PM
CobraCDN's Avatar
Yep thats good advice I agree
Cheers
Old 04-28-2006, 05:03 PM
thanks alot ill try that
