Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 07-18-2002, 08:22 AM
born2speed born2speed is offline
Send a message via AIM to born2speed
Control Arms hitting inner fender? HELP!!!
I searched and looked at other threads, but my case is different. My car is dropped about 1.75 -2" I have a finger gap in the front. Well my upper control arms are hitting the inner fender and has caused damage to the body (paint is chipping off in side the engine bay right next to the shock mounts). My car does have a camber kit and is aligned to very little negative camber. My question is, why are my control arms hitting? When the car is on the ground the control arms are angled very high up and the outer edge is actually hidden by the seam at the top of the wheel well. Should the control arms be angled this high up. It seems to me that there is no other way they could be since the fork they are attached to is a fixed length to the wheel.
How can I fix this problem.
"The only thing interfering with my learning is my education" - A. Einstein
1995 GBP Integra GSR
ACT S/S Clutch
Toda Chromoly flywheel
Weapon-R Intake
Weapon-R Coilover Sleeves
Koni Yellows
RS*R SS Catback Exhuast
Rota Subzero 17x7.5 w/ Nitto 555 205/40
AEM Big Brake Kit (all 4 corners)
Type-R Spoiler (straight from Honda of Japan)
OEM Red A Emblems
Old 07-19-2002, 04:48 AM
Duatone Duatone is offline
check out my knowledge on the other thread from strodda, if you need more i can do it
so far:
1990 accord ex
JDM F22B DOHC/Nakayama cold air intake/Nakayama exhaust/18" Enkei Zoku painted black/Yokohama Parada Spec II/Full air ride/shaved doors & mouldings/VIS R34 front bumper blah blah blah...
Old 07-19-2002, 07:16 AM
hey man, I saw the other post. My question for you is, is there another way to get around this? Why am I having these problems and no one else with an Integra is?
ACT S/S Clutch
Weapon-R Intake
Koni Yellows
OEM Red A Emblems
Old 07-19-2002, 02:39 PM
strodda strodda is offline
does everyone else have a camber kit? i never had the problem until i had it aligned correctly. you could have it slammed and it wont hit because the more you lower it, its bringing the arm more inwards and up. the further you go back and up, the higher the well is, so its not going to hit. the problem is, when it comes to correcting camber... the more its lowered, the less it'll take to hit. think of it as an upside-down V, the higher you go up, the less room you have to work with.
to get around it you can bend out the frame, cut it as he stated, or keep the negative camber. but im assuming you have less room to work with since your car is alot smaller than mine.
Old 07-19-2002, 06:54 PM
I dont know how it works for an integra yet, but when you lower your car, it shoves your a-arm up into the fender well at an angle, but when you lower it and get your camber adjusted, it shoves it straight upward because when you adjust your camber, or put on a camber kit, all that does it push the a-arm further away from the chassis thus closer to the fender, and no, i have not found any other way around it, i was amazed that it even had to be done, maybe somewhere they have a magical operation, but i never found it, plus you dont need all THAT huge of a hole, plus if you fab in some plexi, it looks pretty good.
so far:
1990 accord ex
Old 07-20-2002, 12:07 AM
Dezoris Dezoris is offline
Mod for life
Send a message via AIM to Dezoris
what kind of camber kit do you have, and what are your alignemnet specs and your shock and spring combos, along with what size rims and tires you use and the offset.
M.Sanew - AutomotiveArticles.com
Weight of control arms, tailgate & fenders SidneyCanada 4Runner/GX470 1 01-06-2011 01:49 PM
Frt Lower Control Arm scotschult Crown Victoria 12 12-17-2010 09:04 AM
Help for Control arm bushings mikev46614 Rendezvous 2 10-01-2010 06:42 PM
Cutting control arm bad idea? SAFE? HELP!!! INeedSpeed '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 22 05-05-2002 04:11 PM
