Old 04-26-2006, 12:39 PM
tetrahydro tetrahydro is offline
Banned
burning dvd's - AVN5425
I have a question for all of you guys out there with in dash DVD players, I personally have the AVN5435, I DO NOT have a DVD burner on my computer but I'm curious if there is a way that I could still burn DVDs or Small video files such as music videos onto like data discs and will it play? If its possible what do I need to do... thanks in advance. -Brandon
Old 04-27-2006, 07:01 AM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: burning dvd's - AVN5425
you can try making a video disc with nero, those are playable with almost all dvd players. you burn them on CD-R/RW's
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 04-27-2006, 04:37 PM
highteknology's Avatar
highteknology highteknology is offline
Send a message via AIM to highteknology Send a message via MSN to highteknology
you can still burn a video disc it just won't be a DVD. as stated above, you could use NERO and create a video disc. It should play in your unit and you can even add menus to it if you really wanted to. the only thing you will be limited to is space. seeing how a CD-R/RW holds about 700 megabytes and a DVD (any format) can hold around 4 gigs.
Old 05-08-2006, 02:59 AM
NAVY IC's Avatar
NAVY IC NAVY IC is offline
You don't even have to use nero, you should be able to save to a disc like you would normally save any kind of file to disc.
Once you load the disc choose the icon and the file should open just like in your home dvd player.
FM/AM tuner
Advanced 24-bit DAC
High-performance DSP:
5-mode soundfield control
9-band EQ
Listening position selector
5V preamp output
CD Changer-ready (2 units)
Rear view camera-ready
Video output for rear monitor
E-LAN data link system
ESN security
